ES motor mounts
Old May 18, 2002 | 06:11 PM
Integra_B18B's Avatar
New User
Default ES motor mounts
Anyone running them on their Integra? How are they? Does the car shake alot? Just curious cause I daily drive and stuff.
Thanks
Old May 18, 2002 | 06:42 PM
96IntegraRS's Avatar
Default Re: ES motor mounts (Integra_B18B)
Buy them. People have said that the vibration was excessive at idle, but there is not much difference at all. Good for controlling wheel hop and a smart idea if your car is a 97 or older (guesstimate). Easy to install the front 2, the rear is more of a pain in the ***. Puts the torque thru the tranny and not moving your motor in the engine bay.
Definitely worth the $30 or so.
Old May 18, 2002 | 06:44 PM
New User
Default Re: ES motor mounts (96IntegraRS)
Not much vibration compared to stock??
Old May 18, 2002 | 06:48 PM
Not enough to make you annoyed. Trust me, I asked the same questions before I bought them, took the chance, and am happy.
To answer your question: A bit more, at idle, than stock. A bit means you can feel it thru the wheel, where as stock you can't. It's fine.
Old May 18, 2002 | 06:51 PM
New User
Thanks!
Old May 19, 2002 | 03:32 AM
EVOTHIS's Avatar
where is a good place to buy them?
Old May 19, 2002 | 06:45 AM
G a b e's Avatar
Banned
Default Re: ES motor mounts (b18c ya)
http://www.inlinefour.com/
Old May 19, 2002 | 04:53 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: ES motor mounts (gsx)
When you insert the mounts does the engine need to be supported with a jack? And where do you the the jack on?
shraz
Honda Civic (2006 - 2015)
Jan 13, 2009 10:33 AM
94IntegraLs04
Mar 24, 2005 07:16 AM
jbscivichb92
Oct 29, 2004 07:49 AM
216.226.142.95:27016
Nov 27, 2003 10:34 AM
OutLuDeD
Aug 15, 2003 11:18 PM
