problems with H&R springs!
does anyone have 29502?
I have a problem determining which are for the front and which are for the back.
there are 4 springs...two with a "HA" marking, and two with a "VA" marking.
could someone please tell me which is supposed to be which? TIA.
Are they coil overs or just springs? If they are springs you should be able to tell by the length. If I remember correctly the rear a longer. You should be able to tell when you go to pull of the old ones. I hope that you have better luck than me. I put on a set of Eibach sportlines and I just pulled them off last week and went back to stock. I put a camber correction kit on it also and pulled all that crap back off. I like the look put didn't like the performance. It made my car wonder a to much. They were good when you got into some corners but the stock were just as good and seemed to have a better spring rate than the Eibachs. The reason I went with the Eibachs was because of the realtime acura's but the use a different type that aren't streetable at all from what I understand. well good luck.
[Modified by 01R184, 3:15 AM 5/19/2002]
prostreetonline
16
Aug 11, 2005 05:54 PM
