B18C5 Swap, Driveshaft Question
Old Feb 8, 2007 | 07:11 AM
Phyreangel's Avatar
Default B18C5 Swap, Driveshaft Question
Hey everyone,
I'm getting a 98 Integra Type R motor from japan and it comes with the 98 Driveshafts. Now, I have a 1990 honda CRX.
I've talked to some people and they say that the 98 driveshafts won't fit the stock CRX hubs since they are too small. Anyone have any suggestions as to what I should do? Some people have told me to switch to a 5 bolt hub, others have said to switch to an EG civic hub (so it's stil 4 bolts). What do you guys think?
Thanks
Jon
Old Feb 8, 2007 | 08:44 AM
dr_latino999's Avatar
Default Re: B18C5 Swap, Driveshaft Question (Phyreangel)
You'll need to switch axles. The JDM ITR axles have a 36mm spline instead of 32mm. Just source a set of USDM Integra axles and you'll be good to go, no need to do all the hassle of 5-lug.
Old Feb 8, 2007 | 08:51 AM
Jonknee's Avatar
Default Re: B18C5 Swap, Driveshaft Question (dr_latino999)
What year usdm integra axles.
Old Feb 8, 2007 | 09:22 AM
crxnj's Avatar
Default Re: B18C5 Swap, Driveshaft Question (Jonknee)
94 95 96 97 98 99 00 01 take your pick.
Old Feb 8, 2007 | 09:26 AM
Creator's Avatar
Doesn't he have to get non abs axels or am I wrong...
Old Feb 8, 2007 | 09:29 AM
crxnj's Avatar
Default Re: B18C5 Swap, Driveshaft Question (Creator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creator &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't he have to get non abs axels or am I wrong...</TD></TR></TABLE>
it doesnt matter, either will work.
Old Feb 8, 2007 | 03:23 PM
Phyreangel's Avatar
Default Re: B18C5 Swap, Driveshaft Question (mr.speaker)
Alright... so I need to get my hands on some USDM integra drive shafts... or i can get the ends changed at some shop to a 32mm end...
would anyone recommend getting the ends changed to a 32mm?
Old Feb 8, 2007 | 04:14 PM
IndySporty's Avatar
Your stock CRX ends will go right on I believe.
Old Feb 9, 2007 | 06:48 AM
Phyreangel's Avatar
Default Re: (IndySporty)
I'm going to guess I can switch the ends myself.. otherwise everyone would be doing it right?
It would seem like i've got two options.
1) I bring the 98 driveshafts to a shop like Teknotik and have them change the ends for me for around 200 bucks
OR
2) Buy new integra driveshafts as you guys have suggested.
If I do the #1 way, Supposingly those driveshafts are stronger since they're JDM, but then if i get integra driveshafts i'll be able to get like 00 integra driveshafts which are "newer" and maybe better. What do you guys think?
Old Feb 9, 2007 | 06:55 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (Phyreangel)
i would go to autozone and get some new axles for $70 a peice with a lifetime warrenty..
vtakef
Jan 21, 2008 07:08 PM
jomama
Nov 21, 2007 12:40 PM
1992 civic Jdm BOY
Dec 29, 2006 08:55 PM
cashkid2004
Sep 26, 2006 01:25 PM
EM1R
Aug 20, 2005 11:28 AM
