How do you dyno and tune a car with automatic transmission?
Old Feb 8, 2007 | 06:53 AM
preludeh22a1's Avatar
Default How do you dyno and tune a car with automatic transmission?
im thinking about getting the car dyno,but the car is automatic and i dont know if i have the right stuff to go to dyno, i dont really want to embarass myself on a shop . suggestions..
Old Feb 8, 2007 | 07:13 AM
'95 BA8's Avatar
Default Re: How do you dyno and tune a car with automatic transmission? (preludeh22a1)
Tie it down and floor it.
Old Feb 8, 2007 | 08:08 AM
mgags7's Avatar
Put it in one of the locked in gears, not just in drive
Old Feb 8, 2007 | 08:12 AM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Put it in one of the locked in gears, not just in drive</TD></TR></TABLE>
Use D3. Shift into D4 after completing the run to make it a little easier on the tranny.
Old Feb 8, 2007 | 11:54 AM
Default Re: How do you dyno and tune a car with automatic transmission? ('95 BA8)
well i know that, do i need some upgraded ecu to have them tuned it or stock ecu is good?i got a sfc controller, are they going to use that to tune it?i have a air fuel gauge its autometer.i dont know if its working right bcoz its always on the lean side.how do u know if its not working right? whats the stock hp and tq for a h22a1? so that i would have a referrence.thnx guys.
Old Feb 8, 2007 | 01:25 PM
Bird333's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Use D3. Shift into D4 after completing the run to make it a little easier on the tranny.</TD></TR></TABLE>
I am interested in this aswell. I have heard some say put it in 2nd and you say use D3 which still changes gears automatically. What is your reason for saying use D3 instead of 2nd?
Old Feb 8, 2007 | 01:40 PM
preludestud11's Avatar
Default Re: (Bird333)
it depends on how the gearing is on your transmission. Generally you do not want it in a really high gear if you are boosting a stock motor, it will cause more heat in the engine.
Old Feb 8, 2007 | 03:52 PM
my9thtry's Avatar
yeah thats a tough one cause if you floor it in D3 youll down shift into second. if you run it in 2 that will work but who has dyno'd in 2nd gear?
Old Feb 8, 2007 | 04:55 PM
BlueLude84's Avatar
Default Re: (my9thtry)
I would just suggest getting a car with a standard tranny...
automatic = dissaster waiting to happen.
Old Feb 8, 2007 | 07:40 PM
M2B4's Avatar
Default Re: (BlueLude84)
lol awesome resolution. sign in window at shop reads: "In order to dyno your car if its an automatic you must sell it and buy a 5 speed sorry for any inconvenience this may cause - MGMT"
seriously if u go to a shop they should know what to do. if they dont then dont let them tune your car
fperra
Honda S2000
May 6, 2005 06:05 PM
HondaIntegraR
Mar 8, 2005 01:35 PM
Traction
Sep 12, 2004 09:55 PM
Del_Slowest
Apr 22, 2004 02:08 PM
satan_srv
Mar 28, 2003 07:01 AM
