lower my car= need help
Old Feb 8, 2007 | 05:39 AM
jimjonez
Guest
Posts: n/a
Default lower my car= need help
ok guys. i have a 1990 honda accord dx. i wanna lower it about 1.5 inches in the front and about 2 inches in the rear. right now my car is higher in the back than it is in the front. i want my car to look like it is parallel with the ground! what is a good kit or spring to use on my cb7 and not too costly
Old Feb 8, 2007 | 06:07 AM
EvenStar's Avatar
Default Re: lower my car= need help (jimjonez)
sprint springs and tokico hp's.
Old Feb 8, 2007 | 06:22 AM
TouringAccord's Avatar
H-T Order of Merit
I believe most spings are going to be staggered in the opposite direction. Meaning most spring sets are going to be lower in the front than in the rear, or the same all around. If you want to go the other way like you've stated, you may want to look into full coilovers like TEIN or sleeves like ground control so you can drop it however much you'd like.
Also make sure you get aftermarket struts to handle the lower springs or sleeves. Obviously you wouldn't need aftermarket struts if you go full coilovers.
Old Feb 8, 2007 | 07:01 PM
typeR#0427's Avatar
Default Re: lower my car= need help (TouringAccord)
get real coilovers, they are more pricey but well worth the money.
TEIN
Ground Control
Omnipower
Old Feb 8, 2007 | 07:17 PM
hondaccord's Avatar
Default Re: lower my car= need help (hamB18C5)
have any of you heard of Ksport? are they any good, or just knock offs?
Old Feb 8, 2007 | 08:55 PM
iam7head's Avatar
Default Re: lower my car= need help (EvenStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvenStar &raquo;</TD></TR><TR><TD CLASS="quote">sprint springs and tokico hp's. </TD></TR></TABLE>
worst combo, ever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C5 &raquo;</TD></TR><TR><TD CLASS="quote">get real coilovers, they are more pricey but well worth the money.
TEIN
Ground Control
Omnipower
ground control is a sleeve over, omnipower is having abunch of broken part, lower end tein is crap
most people think their front is higher because the fender is higher, don't just check the gap because it's not the correct way to check height.
Old Feb 9, 2007 | 07:59 AM
james_ls's Avatar
Default Re: lower my car= need help (hondaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaccord &raquo;</TD></TR><TR><TD CLASS="quote">have any of you heard of Ksport? are they any good, or just knock offs?</TD></TR></TABLE>
K-Sport makes some pretty decent products.
Several of my friends SWEAR by their K-Sport kits...I just don't have the money to RE-DO my suspension...or I would.
HondaSPEC99
Aug 7, 2010 06:53 PM
polyhonda
Suspension & Brakes
Oct 14, 2007 05:26 PM
lookn4speed
Suspension & Brakes
Sep 22, 2007 10:37 PM
TougeCoupe
Jul 10, 2004 07:05 AM
PA MATT
Jul 26, 2003 02:07 AM
