Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
CR-V problem
Old Feb 8, 2007 | 03:03 AM
Decatur's Avatar
Default CR-V problem
Hi all!I need a technical suggestion regarding a problem with 1998 Honda CR-V,4WD,Auto,4 cyl.When drive the car ,steering pulls due to slipping differential and there is noise particularly on turning.I had a mechanic look at it who said it was the differential slipping and not the gearbox.My question is:What does that means?Is it possible to disconnect the front axcels,and keep driving as a RWD?Thank's in advance for paying attention,George.
Old Feb 8, 2007 | 04:01 AM
golf's Avatar
Default Re: CR-V problem (Decatur)
I'm not sure if I follow you.
Is it possible the noise is a bad cv joint ?
You wouldn't be able to disengage the front axles since it's full time front wheel drive.
Old Feb 8, 2007 | 08:05 AM
Decatur's Avatar
Default Re: CR-V problem (golf)
Actualy i haven't see the vehicle.This is everything i know.The guy just told me "there is a banging noise when driving and louder banging noise when turning, noise and steering pull came on suddenly without warning, vehicle not driven since.
"He is not a specialist,so the info is limited...
Old Feb 9, 2007 | 06:10 AM
Ross 2.0's Avatar
In a Junkyard near you.
as in the rear differential? You need to change the fluid in it with Honda "Dual Pump" fluid. That will eliminate the noise. This is a very common maintenance issue.
It can not be driven as a RWD due to it's configuration.
Murilo EJ1
Transmission & Drivetrain
Jan 16, 2019 12:30 PM
burntkookie
Jan 19, 2010 06:09 PM
qhondak
Oct 6, 2009 10:17 PM
Decatur
Feb 8, 2007 08:53 AM
sporkcrx
Acura TL, RL & ZDX
18
Oct 28, 2004 05:59 PM
