Cars, Turbos, Drag radials, Exhaust, Clutches, Blocks
Skunk2/RSR Del sol exhaust-great condition -- $400 obo
b16 block -- no pistons, rods, oil pump, oil pan or pickup - $70 obo
Tial 35mm wastegate -- SOLD
ACT xtpp w organic disc and clutchmasters flywheel for H22 -- $425 obo
ACT 90-91 teg b-series organic disc practically brand new -- $100 obo
Hasport H22 into EG race mounts-full kit -- $400 obo
JE 81mm b-series pro seal rings-brand new in box -- $100 obo
JE 81.5mm b-series pro seal rings-only 3 cylinders brand new in box -- $75 obo
LS obd2 distributer-housing, all sensors and wiring and cap, no coil or rotor -- $100 obo
Full coilovers with 2 sets of springs up front-1 set is custom 900lb eibachs which is 2 days old of use. Rears in great condition, front struts need rebuilt -- $375 obo
H22 valves, springs, and retainers -- $100 obo
H22 Stock intake mani-no injectors -- $75 obo
92-95 Civic dx front spindles with fairly new bearings-no brakes -- $50
ACT b-series hydro clutch-xtpp w/organic disc-300 miles of use -- SOLD
Turbo kit-Turbonetics t3/to4e, tial 35mm wastegate, Apexi FMIC, revhard mani (has crack that needs to be easily fixed), stainless dumptube, 2.5" - 3" a/c compatible downpipe w/flex and cat delete, precision 880cc injectors, inline pro fuel rail, stainless feed line, 2 different return lines one is -10 and other is -12, turbonetics fittings and oil pressure sensor, 2.25" and 2.5" I/C piping for a gsr, HKS super sequential BOV, all t-bolt clamps and silicone couplers, Turbonetics manual boost controller, GM 3-bar map sensor with pigtail, and LS hondata socketed ecu (needs blue box and interference cable) -- SOLD
OneFab type 1 turbo manifold-has a crack on #1 runner -- $325 obo
LS turbo 92 Civic 4-door-400whp 300tq -- PM for details
92 hbp Civic Hatch-Built ls/vtec 190whp 140tq -- PM for details
Turbonetics Deltagate Wastegate w/7lb spring -- SOLD
BFG Drag radials 205-50-15 - 10 passes on them, tons of life. Only track driven -- SOLD
Bogart Drag-on Flys- 14x9 perfect condition -- $375 obo
H22 oem pistons and rods-48k of use -- $125
96+ Civic Test pipe with o2 senson - 16.25" long 2.25 diameter -- $40
Unorthodox racing crank pulley
Modified by JDMH22HATCH at 10:24 PM 2/14/2007
Modified by JDMH22HATCH at 9:28 PM 2/27/2007
Modified by JDMH22HATCH at 2:15 AM 3/1/2007
Modified by JDMH22HATCH at 2:02 PM 4/8/2007
Modified by JDMH22HATCH at 9:31 PM 4/8/2007
Modified by JDMH22HATCH at 4:18 PM 4/16/2007
Modified by JDMH22HATCH at 9:59 PM 4/23/2007
I'm waiting on a few local people that are interested, but I'll let you know if it falls thorugh. Thanks.
