Compression Numbers on a B18C1
Old Feb 7, 2007 | 09:22 PM
mtpktz.'s Avatar
Default Compression Numbers on a B18C1
For those of you who have had their compression tested, what #'s did you come out with? Mods?
I'm curious what I should be looking for, because I am up 6,300ft above sea level, and I'm looking for some near sea level numbers.
Any and all help is appreciated.
Old Feb 7, 2007 | 09:54 PM
numbnuts22715's Avatar
compression should be around 200 or so psi per cylinder.
Old Feb 7, 2007 | 09:55 PM
mtpktz.'s Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">compression should be around 200 or so psi per cylinder.</TD></TR></TABLE>
Hm.. so factor in the elevation difference, should be about 185ish.
Thanks for the response.
Old Feb 7, 2007 | 10:11 PM
Haleiwa-Brando's Avatar
Default Re: (mtpktz.)
This 'target' compression your looking for is irrelevant. What your looking for is consistency through all four cylinders.
Old Feb 7, 2007 | 10:17 PM
mtpktz.'s Avatar
Default Re: (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">This 'target' compression your looking for is irrelevant. What your looking for is consistency through all four cylinders.</TD></TR></TABLE>
This is what I always thought, but was recently told that even if all cylinders were 160-165, the numbers are low, even though they are consistent.
Old Feb 7, 2007 | 10:21 PM
Another major factor is how many miles are on the engine. Obviously, a new engine will have high compression numbers as the rings are fresh and so is the hone. An engine with high miles will generally have lower compression numbers. That doesn't mean it isn't healthy though.
Look for consistency.
Old Feb 7, 2007 | 10:23 PM
mtpktz.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Another major factor is how many miles are on the engine. Obviously, a new engine will have high compression numbers as the rings are fresh and so is the hone. An engine with high miles will generally have lower compression numbers. That doesn't mean it isn't healthy though.
Look for consistency.</TD></TR></TABLE>
Thanks for the information.
valiente540
Feb 2, 2008 11:38 PM
dbiker207
Nov 26, 2006 07:10 AM
Combustion Contraption
53
Nov 18, 2006 09:50 PM
Mr.OB*GYN_Rhett
Aug 17, 2006 10:54 PM
DOHCarp
Sep 11, 2003 07:10 PM
