b20 w\ b16 tranny
I did searching and came up with both opninions postive and negative. Would a B20b bottom end w\ a b16 head, be a good idea? And if so would it be ok to use the B16 tranny, or would an ls tranny be better??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueRex1020 »</TD></TR><TR><TD CLASS="quote">i heard to get the best out of a b16 tranny ur motor has to be able to be reved pretty high.....i'm not 100% sure if thats true though...</TD></TR></TABLE>
Misconceptions about transmission gearing always puzzle me. Having longer gears is better for boost, B16 trannys suck for ls motors, etc.
A shorter tranny is a shorter tranny regardless of your engine situation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project midnight »</TD></TR><TR><TD CLASS="quote">will the b16 tranny even fit on the b20 block? </TD></TR></TABLE>
yes.
yes.
yes it fits fine just like all other b-series tranny's . and shorter gearing is always the way to go unless you have a big turbo. you will always accelerate faster with shorter gears. why do you think they make 4.9 finals for type r's which already have close gearing
so the tranny i should stick with is the stock b16 one, i was thinking about switching the 5th gear w\ an Ls one so it is longer(for DD purposes), is there any other fabrication work needed to my car, sence i already had a B in there would it jus pop in ?
B16 tranny will be nice, but maybe something will a little taller gears like a GSR tranny would work best. b20vtec.com also has some fun info for b20s etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">yeah you need a b16 tranny..the ls tranny is horrible.</TD></TR></TABLE>
fixed
it bogs my arpox 200WHP lsvtec down.
LS tranny isn't good for going fast.
fixed
[/QUOTE]
[/QUOTE]
Hmm aren't those statements contradictory. My B16 tranny works great on my LS.
[/QUOTE]Hmm aren't those statements contradictory. My B16 tranny works great on my LS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman »</TD></TR><TR><TD CLASS="quote">I did searching and came up with both opninions postive and negative. Would a B20b bottom end w\ a b16 head, be a good idea? And if so would it be ok to use the B16 tranny, or would an ls tranny be better??</TD></TR></TABLE>
I would go with the shortest gearing you can tolerate to drive on the street. You may want to run a b16 1-4 gears, but retain the LS 5th for cruising speeds.
FYI: I drove a b20 w/ ys1 short-gears on the racetrack. It was very nice. Didn't drive it on the highway though.
