crx hf f/s and b-series toda,buddyclub, parts2
Old Feb 7, 2007 | 04:08 PM
kantfadedisazn's Avatar
Default crx hf f/s and b-series toda,buddyclub, parts2
yeah i got a the following for sale it is missing the head thats it
1990 crx hf shell with jdm b16 block from hmo, jdm s1 cable tranny with clutch masters stage 3 clutch set, teggey axels, wired for obd1, hx wheels w/new falkens and hasport mounts and kyb shocks, tein springs, dc sports 4-2-1 ceramic header, omni power test pipe, greddy sp2 exhaust, wahlboro 255lph fuel pump, optima red top battery relocated to the rear in scca approved box, Denso Iridium spark plugs NGK Spark plug wire, B&M no bend short shifter Energy shifter bushings, Brand new wheel bearings don't even have 1000 miles on them. New Tie Rod ends New ball joints Just had an alignment Old Place Racing crossmember, when you look down into the engine bay you can see the ground crossmember takes up next to no space. Honda civic EX brakes up front(10.2 inch rotor) New pads and new calipers DA brake booster and Master cylinder,Sony headunit
and speakers the works, body has some dings and paint is lil faded $2000 firm pm me about the shell. clean title in hand and read this carefully the item s mentioned that are part of the shell will not be parted out understand good clear!
jdm b16a head exept cams and cam gears.,and valve cover is has cut out for cam gears but its ghetto, has rocket motorsports valve train, has five angle valve job, cleaned resurface and the works-$500
pair of toda cam gears that came off my b16 -$220
buddyclub spec 3+ cams new $550
jdm style steering wheel black with red stiching w/ mugen horn button $100
pair of black 4 point harness $100
recaro style carbon seat i have both with brackets $600-sold
Short shifter with authentic spoon shift ****-$100 It comes in the original spoon box too
AEBS type r intake manifold ported to dh-racing 74/69mm tb with dh-racing fuel rail and dh-racing fpr, with sensors and all $450
this is what the tb looks like
brand spanking new buddyclub racing spec head gasket-$100
carbon fiber steering wheel five hole-$75obo
b-series axels 1 driver 3 passenger $50 each
obd1 p30 ecu virgin $150
i got a socked obd1 ecu... its got a dohc base map in it right now and it ran my ls/vtec for 60k miles no problem its a mix of spoon and j-racing, but with a different chip will work with any obd1 honda and also have ob2-obd1 coversion harness
im asking $220 for both
lmk
no rev limit
no top speed limit
vtec cross over set at 5600k
no nock sensor
and thats about it for now pm me if interrested cuz ima not checking the thread that often and no lowballling or bullshit
Old Feb 8, 2007 | 10:23 AM
screwballz's Avatar
Default Re: crx hf f/s and b-series toda,buddyclub, parts2 (kantfadedisazn)
bump for you bro.
i think i lost your number when you sent it to me. let me get that valvetrain. haha.
Braco11
Mar 4, 2011 03:21 PM
JDM*Fiend
May 6, 2007 09:40 PM
kantfadedisazn
Sep 27, 2006 06:52 PM
M15
Aug 17, 2006 01:17 PM
