Will Both CTR cams work with stock gsr valvetrain???
Old May 18, 2002 | 03:29 PM
IgniteTeg's Avatar
Default Will Both CTR cams work with stock gsr valvetrain???
Was wondering if I was to put in both ctr cams intake and exhaust will it work with my stock gsr valvetrain??? Meaning is it too agressive?? Or my gsr valvetrain can handle it?? Do I have to upgrade my valvetrain?? I'm not looking into upgrading my valvetrain so will these ctr cams work fine with my gsr valvetrain? Btw, I have a 01 gsr if that helps. Thanks for the help.
Old May 18, 2002 | 03:44 PM
2kgs-R's Avatar
Default Re: Will Both CTR cams work with stock gsr valvetrain??? (IgniteTeg)
I'm plannin on putting ctr or itr cams into my 2k gs-r too. To answer your question, no you don't have to upgrade your valve train unless you raise the rev limiter
Old May 18, 2002 | 04:09 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
Default Re: Will Both CTR cams work with stock gsr valvetrain??? (2kgs-R)
yes it works
Old May 18, 2002 | 04:39 PM
Maximo's Avatar
i have done it in my car...95gsr
u hafta get your cams tuned or switch the ecu or else u will have some power loss right before vtec kicks in.....my ITR cams gave me 5 WHP untuned and almost 10 WHP after tuning....you ill love the sound of your new cams.....im runing stock valve train and have been shiftin at around 8200 no problem (rev limiter is 8700)
hope this helps and good luck
Old May 18, 2002 | 11:30 PM
IgniteTeg's Avatar
Default Re: Will Both CTR cams work with stock gsr valvetrain??? (NXTEG)
Will it run fine with the stock gsr ecu with the ctr cams?? What kinda powerloss am I looking here?? Know at what certain rpm? When vtec xover? Thanks.
Old May 19, 2002 | 12:07 AM
sa21199's Avatar
stock ecu is ok and so is stock valvetrain but plan to upgrade sometime
Old May 19, 2002 | 12:20 AM
IgniteTeg's Avatar
Default Re: Will Both CTR cams work with stock gsr valvetrain??? (sa21199)
Do I really gotta upgrade the valvetrain?? I'm not planing on going all motor. Planing to turbo it soon. So upgrading the valvetrain reving more is outta my opinion. Thanks. Only Boost
Old May 19, 2002 | 12:21 AM
neo1z's Avatar
um youre vtec xover will be the same, so youll wanna buy a vafc and make youre vtec kick in around 5600 or so
Old May 19, 2002 | 12:23 AM
IgniteTeg's Avatar
Default Re: Will Both CTR cams work with stock gsr valvetrain??? (neo1z)
cool thanks so I just need to up my vtec xover then. Already got a vafc. Well, I'l just try and get it tune and well see just wanted opinions on the ctr cams with the gsr valvetrain. Thanks guys.
99ekb18b
Sep 12, 2008 08:55 PM
94IntegraLs04
May 10, 2006 08:38 PM
crush
Jun 19, 2005 09:53 PM
95egSi
Dec 5, 2004 02:41 AM
IgniteTeg
May 21, 2002 07:14 PM
