Need Pro Tech's help about car starting problem
Old May 18, 2002 | 02:59 PM
benx626's Avatar
Default Need Pro Tech's help about car starting problem
I have a very strange problem with my 92 Integra LS. First off the car starts randomly, meaning sometimes it starts, sometimes it doesn't. It just makes a click sound if it doesn't start. When i turn the key, all i hear is a click but nothing else. I have a new battery, and a new starter, and a new main relay. My electric seatbelts work randomly too. When I drive my seatbelts sometimes goes back and forth. Or it get's stuck somewhere in the middleSomething tells me theres something really wrong with my electrical system. Might be something that my brother did because he installed my alarm system and sound system. The car is automatic, and sometimes when it doesn't start, the S2 gear is blinking when the car is in Park. I would take my car to get fixed, but i hear its very pricey to check the electrical system and I'm low on funds. Please help guys, I want to fix this problem myself.
Old May 18, 2002 | 05:50 PM
Rain_man's Avatar
New User
Default Re: Need Pro Tech's help about car starting problem (benx626)
Ouch. I'm guessing you don't have the service manual for it either.
It sounds like of like a loose wire, I'd recheck all your connections to make sure they're not loose.
Worse comes to worse, remove the alarm and disconnect the stereo. Then return everything back to stock and see if that helps.
Old May 19, 2002 | 03:39 PM
benx626's Avatar
Default Re: Need Pro Tech's help about car starting problem (DarksideDC4)
Thanks for responding. First question, which wires should i start with? There is so many wires. If you can tell me where is the wiring for the starting problem and the wiring for the seatbelts on my car.
Old May 19, 2002 | 04:41 PM
Rain_man's Avatar
New User
I meant reecheck the wires you spliced/connected into to get your alarm and stereo installed. I don't know which wires are the seatbelt and starter wires, as I don't have a G2 Integra.
XpLiZiT
Feb 11, 2014 05:20 PM
Jeanette
Honda Civic (2006 - 2015)
May 27, 2011 07:57 PM
this_guy07
Nov 14, 2008 03:11 PM
ninjapanda
Nov 8, 2006 08:53 PM
peteysmoooooth
Dec 2, 2004 10:39 AM
