Radiator leak every year
Old Feb 7, 2007 | 11:25 AM
indtegra's Avatar
Default Radiator leak almost every year
Hi,
This is the third time its happening to me. First it happened in nov 2002 (@79K) and i replaced with a new radiator + thermostat. In nov 2005(@ 130k), it again happened, the radiator started leaking from the top rim and i replaced it with an aftermarket one from a auto recyclery. but now, in feb 2007 (155k), it started again. I am fed up of this thing. what might be the problem? I live in wisonsin and its chilling cold out these days. -5 degree F. please suggest if there is something i am missing. How much does a total metal radiator cost? is it a denso or showa on an integra 94 ls (5 speed). Is anyone selling a cheap radiator ?
thanks in advance.
Modified by indtegra at 4:41 PM 2/23/2007
Old Feb 7, 2007 | 11:33 AM
CXtypeR's Avatar
Default Re: Radiator leak almost every year (indtegra)
i just bought a mishimoto aluminum radiator. it looks nice. cheap too at $130ish
Old Feb 7, 2007 | 12:16 PM
SuzukaBlueAP2's Avatar
Default Re: Radiator leak almost every year (CXtypeR)
go with an aluminum rad.
The OE ones are known to have flaws and I'm sure the OE replacements do also.
When I had my Teg I bought a Fluidyne, but you don't need to go that extreme.
Old Feb 7, 2007 | 01:41 PM
Madness's Avatar
As stated above, the plastic end tanks on the OE radiators are notorious for failing.
The only way to avoid it permanently is to replace it with a radiator that has all-metal construction.
The first brands that come to my mind are Koyo, Fluidyne and C&R.
Good hunting.
Old Feb 7, 2007 | 01:55 PM
davidluko's Avatar
Default Re: Radiator leak almost every year (Madness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madness &raquo;</TD></TR><TR><TD CLASS="quote">As stated above, the plastic end tanks on the OE radiators are notorious for failing.
The only way to avoid it permanently is to replace it with a radiator that has all-metal construction.</TD></TR></TABLE>
Mine did it too, and I bought a full-aluminum one off radiator barn for $130 or $140 shipped, I forgot the exact amount. It's a little thicker than a stock one, maybe a tiny bit wider, and is painted black to look like stock.
Old Feb 8, 2007 | 08:07 AM
indtegra's Avatar
Default Re: Radiator leak almost every year (Hatch_R)
So you are saying the all aluminium radiator costs around 160$ from radiatorbarn.com and is reliable. it wont leak in future. Will the stock fans fit on the aluminium radiator ? Rite now with the bitter cold here, i am just going to put some stop leak for the time being, and wait for the weather to get warmer to put on the new radiator. I checked with the dealer, he asks 280 $ for aftermarket radiator + 230$ in labor & parts.
~Thanks guys.
Old Feb 8, 2007 | 10:15 AM
Tizight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXtypeR &raquo;</TD></TR><TR><TD CLASS="quote">i just bought a mishimoto aluminum radiator. it looks nice. cheap too at $130ish</TD></TR></TABLE>
Same here
They are cheap and work great
Old Feb 8, 2007 | 10:20 AM
hks369's Avatar
i just replaced mine it was like 110 at orileys but theres probably better , it works really good tho no problems cools really well doesnt overheat anymore,buy a dozen eggs and everytime it leaks crack one into your radiator they proved it on mythbusters it seals up to a qaurter size hole
Old Feb 8, 2007 | 11:06 AM
davidluko's Avatar
Yea radiatorbarn is $130 or $140 shipped for the full aluminum one and the stock fans and cap and everything works perfect with it.
sdinteg
Jun 1, 2010 11:26 PM
1996hondaaccord
Aug 11, 2008 03:11 PM
tyler100
Jul 12, 2008 12:55 AM
vxtirent08
Mar 20, 2008 10:36 AM
eastsideATX
Jul 6, 2005 02:56 PM
