+45mm offset fit under Del Sol
Old Feb 7, 2007 | 01:33 AM
SomeGoodBud2's Avatar
Default +45mm offset fit under Del Sol
I am looking at sqeezin some 15x8 4x100 +42/+45mm offset wheels under my 93 del sol
will this work?
will i have to get special tires?
or roll the fenders?
and what offset for this size wheel I should use for them to fit perfect
thanks in advance for any info leading to perfect fitment of these wheels
Old Feb 7, 2007 | 05:17 AM
Bense's Avatar
that might be too close to the struts
Old Feb 10, 2007 | 07:57 PM
Default Re: (Bense)
You are correct pimp, I guess the only way i could get these wheels to fit without rubbing the inner wall, would be to have an offset of 100+mm
The widest wheel recommended on a del sol is 7.5in i believe; and its not too smart/practicle to run any thing over a 16inch wheel anyway.
I guess its ultimately up to the comsumer reguardless.
Eat my advans
Old Feb 14, 2007 | 11:59 PM
Default Re: (solbrothers)
word, i completely understand now, only need to roll feder for a larger diameter wheel. RGR
I ended up going with 15x7's +43mm
Old Feb 15, 2007 | 12:47 AM
Chrisfrom1986's Avatar
No, a fender roller is to give you clearance on the outside of the tire so it doesnt rub.
Old Feb 15, 2007 | 06:00 PM
Targa250R's Avatar
be professional
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">that might be too close to the struts</TD></TR></TABLE>
Del Sols don't have struts.
It's the trailing arm clearance in the rear you have to worry about mainly. You'd have to run spacers to give a 15x8" +45mm enough space under there depending on the tire, and you'd definitely need to roll the fenders (no getting around that with any 15x8).
my civic
Nov 26, 2012 03:42 PM
DesiDez
Apr 21, 2008 10:45 AM
evil sol
May 14, 2007 02:32 PM
- BSeRiouS -
Feb 24, 2005 12:59 PM
phantom_sol
Jul 26, 2003 12:12 PM
