I need a part number please.
Old Feb 6, 2007 | 08:08 PM
Nataku's Avatar
Default I need a part number please.
I have a small coolant leak and would like to replace the leaking part (the part your upper coolant hose connects to), but I can't seem to find the part number. It's for a 96 GSR.
Any help would be appreciated.
Old Feb 6, 2007 | 08:16 PM
numbnuts22715's Avatar
I'm looking in my helms manual and I cant seem to find where that is... Can you describe where it is on the engine so I can try to find it for you?
Old Feb 6, 2007 | 08:59 PM
Nataku's Avatar
Default Re: (numbnuts22715)
what you are looking at is where the upper radiator hose attaches to the block on B18C1. I was unable to find it in my Haynes manual as well.
Old Feb 6, 2007 | 09:09 PM
CNSK's Avatar
Default Re: (Nataku)
19315-P72-010 COVER, WATER OUTLET ???
talking about that metal piece attach to the head?
http://www.acuraautomotivepart...ormal
if so, dont forget to use hondabond
Old Feb 6, 2007 | 09:13 PM
cb169's Avatar
that hose actualy runs to the head, just call the dealer and decribe where it goes to, tell them its the water housing for the upper radiator hose, its held on by two 10mm bolts to the head
Old Feb 7, 2007 | 05:55 AM
Nataku's Avatar
Default Re: (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">19315-P72-010 COVER, WATER OUTLET ???
if so, dont forget to use hondabond</TD></TR></TABLE>
That appears to be it! Thanks everybody!
If I was going to hand cut out a gasket for this... what material could I make it out of?
Old Feb 7, 2007 | 06:47 AM
cb169's Avatar
just order the gasket with the housing or reuse the old one with some hondabond, it is a black rubber oring
Old Feb 7, 2007 | 03:37 PM
Nataku's Avatar
Default Re: (cb169)
I do not see the gasket in the diagram to order...
Old Feb 7, 2007 | 08:35 PM
CNSK's Avatar
there's no gasket....just apply honda bond around it....and let it stand for a few hours, if not overnight
1998GsRIntegra
Aug 15, 2012 03:19 PM
Blamm!!
Feb 17, 2008 09:15 AM
Zalitore
Jul 2, 2007 10:42 AM
Electrodynamic
Nov 19, 2004 11:53 AM
The-LS
May 3, 2003 04:17 PM
