b18 LS cams on 94 GSR head?
Old Feb 6, 2007 | 06:43 PM
dek1mfk's Avatar
Default b18 LS cams on 94 GSR head?
will a set of b18 LS AEM CAM GEARS be interchangable with a 95 GSR head?
Old Feb 6, 2007 | 06:54 PM
9311dan's Avatar
GSR cam gears have 22 teeth i believe as opposed to the LS 19 teeth, which would mean that you couldn't use the GSR timing belt and water pump w/ the LS cam gears, so my answer is no...
don't quote me on that though....
Old Feb 8, 2007 | 05:58 PM
integdriver4's Avatar
Default Re: b18 LS cams on 94 GSR head? (dek1mfk)
i think he's wrong. the water pump on a gs-r has 22 teeth and on the ls it has 19 teeth, which is irrelivant. the cam gears are the same size between ls and gsr. i can tell you this because the only differrence between an LS timing belt and a GSR timing belt is in the number of teeth on the water pump (22 vs 19).
B18B1-Crx
Jun 18, 2011 07:59 PM
natecivic92
Feb 23, 2008 09:13 PM
steelies
Aug 11, 2005 03:01 AM
GEN2INTEG619
Mar 24, 2005 08:39 PM
tegasaurus
Aug 10, 2003 01:07 PM
