88-91 CRX Si engine harnesses all the same?
I'm trying to help a buddy of mine out. He has an 91 CRX Si with an LS swap.
It's got a hack job of a wiring harness, and the guy who sold it to him did some weird, retarded **** to the interior and engine harnesses.
I was looking at getting him a new Si engine harness to adapt to the LS motor the PROPER way this time. Are all 88-91 engine harnesses the same?
And, another question: Is the interior harness swappable as well? Like if we were to swap the engine harness and the under dash harness that matches it, is it possible without re-wiring the entire car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp »</TD></TR><TR><TD CLASS="quote">hmm, what is different about them? </TD></TR></TABLE>
Curious myself, you know Ryan would know from Ry-Wire.
I read the 88's are different. A couple wires are switched between the two main engine bay plugs. not sure about interior.
although when i had my old 91 std hatchback i put on some 88-89 stock tail lights and the plugs were different for the tail lights. I don't know if they were 88 or 89 though.
88 dosent have the fast idle wires.... so there is 2 extra wires on the drivers side, blue and blk/yellow. Honda uses a diff plug because it needs more positions on 89-91...
Thats all... oh, and its ez to confuse si and hf harnesses, they are different, ya...
I have a 88std but the entire wiring harness in the car is from my old 90 civic si. Their were many differences with the wiring harness especially underneath the dash. I don't remember them all, but I just ended up swaping over everything, fuse box under the dash and bunch of other miscellenous things.
