Accord Battery
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STA »</TD></TR><TR><TD CLASS="quote">thanks guys for the help. is there a battery hold that i will have to lossen?</TD></TR></TABLE>
If you try to take it out and something is holding the battery in place, you'll know.
you need either an 8mm wrench, or a deep socket to loosen the battery tie down, and a 10mm wrench or socket to disconnect the terminals. However, if the terminals were changed, 99% of the aftermarket terminals are either 13mm or 1/2inch.
As for how to remove the battery, start by loosening the tie down untill you can rotate it free from the battery tray and set it aside. remove the terminals and clean them. Reverse install for the new battery.
Cmg178
Dec 20, 2015 03:23 PM
