crankshaft question
i have a h22a1 motor. stock crankshaft mains are 50mm. since all h series have identical block, it's ok to get a crankshaft that is 55mm mains right? i'm planning to stroke 95mm. two options: a custom one w/ 50mm mains from ari for $500 and a custom h23 w/ 55mm mains from blacktrax for $400. which one should i go with?
not all h-series have identical blocks. if your cranks gonna have 50mm mains, then get a 92-97 block, if you need 55mm mains get a 98-01
just use a stock h23a1 crank, its already a 95mm stroke and has 50mm mains
you should really just make a thread on every little part that you are looking at buying for your engine. That would be alot better than making ONE thread with all your questions.
tonylude94
Jul 25, 2003 10:02 AM
