mpfi swap problem :-(
Old Feb 6, 2007 | 03:54 PM
yz125rider21's Avatar
Default mpfi swap problem :-(
ok the motor is getting spark and I hear it pumping fuel...I bought a harness coverted from dpfi to mpfi from Carlos on here and I cant get car to start running...I am getting code 20 but I dont think that has anything to do with car starting does it???
Old Feb 6, 2007 | 04:03 PM
janz3n's Avatar
Default Re: mpfi swap problem :-( (yz125rider21)
if youv got a 90-91 civic with a 88-89 ecu then you'll get code 20 all the time because 88-89 had an electronic load detector in the underhood fuse box. 90-91 doesnt have it.. doesnt effect anything , mine has code 20 because of this. however if your car is 88-89 and has the same ecu then im not sure if it would cause the car not to start .
Old Feb 6, 2007 | 04:09 PM
jlicrx's Avatar
Default Re: mpfi swap problem :-( (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">if youv got a 90-91 civic with a 88-89 ecu then you'll get code 20 all the time because 88-89 had an electronic load detector in the underhood fuse box. 90-91 doesnt have it.. doesnt effect anything , mine has code 20 because of this. however if your car is 88-89 and has the same ecu then im not sure if it would cause the car not to start .</TD></TR></TABLE>
that is only for Canada models - USDM 90-91 have ELD
Old Feb 6, 2007 | 04:29 PM
welnow we think we might bot be getting fuel but the pump comes on...
Old Feb 6, 2007 | 06:04 PM
janz3n's Avatar
Default Re: (yz125rider21)
oh .. didnt know that . sorry
Old Feb 6, 2007 | 07:02 PM
any clue why???
Old Feb 6, 2007 | 07:28 PM
Tippyman's Avatar
Default Re: mpfi swap problem :-( (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
that is only for Canada models - USDM 90-91 have ELD</TD></TR></TABLE>
Yup, my 91 std. has it. I was like WTF when I looked up the code.
Old Feb 6, 2007 | 07:49 PM
good start so far....work on hondas all the time but the simple firing order screwed with my head.... i went from left to right 1-2-3-4 instead of 4-3-2-1 on head...silly mistake but will fix it in morning dont wanna get hands dirty before my lady gets here or she kill me haha
Old Feb 6, 2007 | 08:40 PM
Tippyman's Avatar
What kind of spark plug wires are you using? Mine won't let me, they are length specific.
Or did you mix it up on the dizzy?
Old Feb 6, 2007 | 09:37 PM
2poor2tune's Avatar
yeah probly i dizzy mistake. i did the same thing when i did my first swap. im impatient tho so right away i sold the zc i had in it for a t3/t4 zs gayness turbo and a 800w kanwood amp. but ended up with a b16 so all is good.
Old Feb 6, 2007 | 11:19 PM
screwed it up on dizzy but its dark out and figure it out after work tomorrow and will let everyone know...cross fingers...just the car my friend bought someone did a shade tree mechanic wire job on itttt
Old Feb 6, 2007 | 11:32 PM
Rywire's Avatar
Look for a random green/red wire to put back into b19 to clear your code... Let us know more info soon
Old Feb 6, 2007 | 11:38 PM
ryan I think that wire is just sitting there, I will look into that tomorrow thanks
Old Feb 7, 2007 | 05:12 PM
update got car to start but sounds like its miss firing and doesnt want to stay running...need help please
Old Feb 7, 2007 | 05:22 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">update got car to start but sounds like its miss firing and doesnt want to stay running...need help please</TD></TR></TABLE>
Timing? Sure the firing order is correct? Are all the injectors working?
Old Feb 7, 2007 | 07:16 PM
ok solved it all one plug is in wrong on back of manifold...now y does my TB keep sticking on me i clean it out and lubed it and still sticks....like I push gas in and let off it will stick at about 1400 rpms....also tach is not work in car after the mpfi swap....any idea why that might be???
Old Feb 7, 2007 | 07:17 PM
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Look for a random green/red wire to put back into b19 to clear your code... Let us know more info soon</TD></TR></TABLE>
hey the wire is in and still throwing code 20 :-(...only code I am getting
Old Feb 7, 2007 | 07:43 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">ok solved it all one plug is in wrong on back of manifold...now y does my TB keep sticking on me i clean it out and lubed it and still sticks....like I push gas in and let off it will stick at about 1400 rpms....also tach is not work in car after the mpfi swap....any idea why that might be???</TD></TR></TABLE>
My throttle did this also.
I had to adjust the cable some more. Play with the two nuts on the cable until you find the right place. Mine's perfect now.
Tippyman's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Play with the two nuts </TD></TR></TABLE>
Lol
Old Feb 7, 2007 | 08:00 PM
haha...but ya we tried that...I just try to adjust that lil needle tomorrow on bottom of the tb if nothing happens I just gonna have to get a diff tb and go from there
Old Feb 7, 2007 | 08:31 PM
ChickenH's Avatar
the throttle stop? if you get it too far screwed in the throttle plate goes past closed to open and when you step on it it sticks. take the cable off and look at the plate and make sure its closing all the way and not past closing . make sure it opens freely . if youve adjusted that throttle stop your tps sensor will be off also. throttle stop is not supposed to be adjusted. but if it is you could use a digital multi meter to check the tps to see if its set right.
Just something that happened to me with a used throttle body once that someone had dicked around with before i got it.
monster d
Jun 12, 2013 10:20 PM
ntegrar
Aug 6, 2012 01:09 PM
welfarepc
Jul 24, 2007 04:39 PM
EeeJayEight
28
Jul 25, 2004 12:07 AM
