oil leaking thru exhaust
Old Feb 6, 2007 | 03:52 PM
SLPR's Avatar
Default oil leaking thru exhaust
me n my friend decided to check out my crx today. so i crunk it up...no problems... let it idle for 15 minutes...no problems... test drove it...runs perfect... but we noticed a lil bit of oil, or sum kinda black substance was comin out of my exhaust tip. what could this be? and what is the cure?
Old Feb 6, 2007 | 03:59 PM
Crx Jimmy's Avatar
Default Re: oil leaking thru exhaust (SLPR)
there is a lot of carbon in an old exhaust, a byproduct of combustion can sometimes be water, when the hot water(steam) mixes with the carbon it can cool as it leaves the exhaust tip and make a black liquid, it is normal unless its in extreme quantities
Old Feb 6, 2007 | 04:00 PM
janz3n's Avatar
Default Re: oil leaking thru exhaust (Crx Jimmy)
hahahaha
Old Feb 6, 2007 | 04:09 PM
SLPR's Avatar
i wasnt sure what it was. but it isnt thick like oil and really looks watered down whatever it is. but naw, its very lil that comes out. thanks for the input.
btw... would purchasin a new exhaust eliminate it? and would this cause the high reading of CO on my emissions test?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">there is a lot of carbon in an old exhaust, a byproduct of combustion can sometimes be water, when the hot water(steam) mixes with the carbon it can cool as it leaves the exhaust tip and make a black liquid, it is normal unless its in extreme quantities</TD></TR></TABLE>
Old Feb 6, 2007 | 06:06 PM
janz3n's Avatar
exhaust has nothing to do with your problem.. you can buy a new one if you want to waste your money. the high CO in your emissions test has ntohing to do with your exhaust.. its your engine. your engine is putting to much CO out which is forming inside your exhaust.
Old Feb 6, 2007 | 09:49 PM
SLPR's Avatar
Default Re: oil leaking thru exhaust (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">exhaust has nothing to do with your problem.. you can buy a new one if you want to waste your money. the high CO in your emissions test has ntohing to do with your exhaust.. its your engine. your engine is putting to much CO out which is forming inside your exhaust. </TD></TR></TABLE>
ok...so whats the solution? what could be costin it to have such high CO? 02 sensor maybe?
Old Feb 7, 2007 | 03:06 AM
janz3n's Avatar
i really dont know.. im not an expert on engines.. im sure someone on here knows. maybe its o2, could be something els though. maybe your burning tons of oil. and your rings are shot.
Old Feb 7, 2007 | 04:12 AM
ludesrv's Avatar
If your oil consumption doesn't increase, do a tune up and get it timed correctly.
Old Feb 7, 2007 | 04:22 AM
Creator's Avatar
I think you have little to worry about. Your engine will always produce some carbon and water. I imagine it may indicate a problem if you produce a lot of it...like say a puddle on the ground after only warming it up.
Old Feb 7, 2007 | 05:36 PM
SLPR's Avatar
Default Re: oil leaking thru exhaust (Creator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creator &raquo;</TD></TR><TR><TD CLASS="quote">I think you have little to worry about. Your engine will always produce some carbon and water. I imagine it may indicate a problem if you produce a lot of it...like say a puddle on the ground after only warming it up.</TD></TR></TABLE>
naw, its like i said... very little... hardly ever makes a puddle, but when it does, its a small one. and yea, it only happens while its warming up.
Old Feb 7, 2007 | 05:51 PM
janz3n's Avatar
i dont know why this thread is still going really.. you have nothing to worry about.
vodkaTM
Dec 7, 2009 01:28 PM
udechukwu
15
Oct 12, 2009 11:54 AM
westside teg
Jul 28, 2006 10:52 AM
Haleiwa-Brando
Feb 28, 2006 04:39 AM
blackdude
Mar 25, 2004 10:58 AM
