Will this fit and operate?
Old Feb 6, 2007 | 02:13 PM
JDM_EK4_Coupe's Avatar
(banned)
Default Will this fit and operate?
I dont have AC, but I would like for it to light up. Can I make it happen?
Id like to put it in my 98 Coupe
Old Feb 6, 2007 | 02:27 PM
Nate047's Avatar
Default Re: Will this fit and operate? (JDM_EK4_Coupe)
Do you mean just the "A/C" light? My hatch does'nt have A/C either, but when I press the button, the light still turns on. BUT, it's the dash from a 99 Si, so that may have something to do with it...
Old Feb 6, 2007 | 02:31 PM
(banned)
Default Re: Will this fit and operate? (Nate047)
Ima try my luck
Old Feb 6, 2007 | 03:54 PM
EK FLY's Avatar
WONT WORK 99 -00 civic climate control are electrical 96-98 are controlled by wire u will have to swap all the parts from a 99-00 civic like ac fan and stuff under ur dash
Old Feb 6, 2007 | 03:57 PM
BlueIntegraBoy's Avatar
You can put it in and have it light up, but won't be functional unless you do a 99-00 climate control conversion.
Old Feb 6, 2007 | 03:59 PM
YoungKadafi's Avatar
which i have alot of the bolt on parts for sale, except the harness and stuff.....super easy swap
Old Feb 6, 2007 | 04:18 PM
(banned)
Default Re: (YoungKadafi)
Are there any threads on how to do the swap?
Old Feb 7, 2007 | 05:59 AM
(banned)
Default Re: (JDM_EK4_Coupe)
Old Feb 7, 2007 | 06:05 AM
pdiggitydogg's Avatar
yes...search next time
https://honda-tech.com/zerothread?id=605432
Old Feb 7, 2007 | 06:09 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (pdiggitydogg)
just buy a 99-00.
It's not worth all the headache. The 99-00 climate control is nothing to write home about.
Old Feb 7, 2007 | 07:33 AM
https://honda-tech.com/zero...26417
Old Feb 7, 2007 | 11:50 AM
the swap takes 2 hours, max....easier than swapping out a header......
You need the 99-00 climate control, harness, 12v resistor, bottom half of the blower motor, all the brackets and electronic sliders, and the ducts directly behind the Climate controls
Its all plug and play after that, took me 2 hours to install, perfectly working 99-00 climate controls in my 96ex.
Most people think you need the heater/ac/blower from the 99-00, but really its ALL THE SAME. you just need the 12v relay, and the bottom of the blower, and the electronic sliders, to replace the Manual ones, and any helms will show you schematics on how this is setup.
seriously that whole how to, was the biggest waste of time, since its all interchangable
BOOM problem solved
belairbrian
Jan 30, 2022 07:01 PM
Azavala
Jan 4, 2016 04:08 PM
JDM_EK4_Coupe
Feb 7, 2007 07:31 AM
92b16hatch
Jul 12, 2006 08:50 PM
mjrage
Aug 5, 2003 02:11 PM
