Somethings Wrong with my integ
Old Feb 6, 2007 | 01:55 PM
lsturbogrey95's Avatar
Default Somethings Wrong with my integ
My car idles fine but can only rev to 4500 rpms and i have no idea why it is acting so wierd ... could it be my FMU hurting the car? please fill me in if u have any ideas
Old Feb 6, 2007 | 03:11 PM
non_vteccc's Avatar
we need some more info on what kind of car you have, miles, mods, etc etc. try to be a little more specific
Old Feb 6, 2007 | 03:26 PM
bendw99's Avatar
Your car is in limp mode. What did you do to the car last, install a FMU? Whatever mod you just did put your car in kinda of a "safe mode". Its controlled by your ECU. You might be able to reset the ECU to get it back in normal mode, but the problem is likely to arise again. Need more information to accurately tell you whats happening.
~Ben
Old Feb 6, 2007 | 04:16 PM
qwk db8's Avatar
Default Re: (bendw99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bendw99 &raquo;</TD></TR><TR><TD CLASS="quote">Your car is in limp mode. What did you do to the car last, install a FMU? Whatever mod you just did put your car in kinda of a "safe mode". Its controlled by your ECU. You might be able to reset the ECU to get it back in normal mode, but the problem is likely to arise again. Need more information to accurately tell you whats happening.
~Ben</TD></TR></TABLE>
my thougth exactly
Old Feb 6, 2007 | 04:56 PM
RS'R''s Avatar
whats an FMU?
Old Feb 6, 2007 | 06:09 PM
SXEtony's Avatar
Default Re: (RS'R')
The letters FMU stand for "Fuel Management Unit". Basically, an FMU is a fuel pressure regulator for turbo charged cars
Old Feb 6, 2007 | 11:12 PM
spoolinfool's Avatar
Default Re: Somethings Wrong with my integ (lsturbogrey95)
fitting from the middle of the fmu connnected to the fuel return ?Fitting on the outer perimeter of the fmu connected to the the bottom of your stock regulator?
If so do you have an inline fuel pump?
Old Feb 6, 2007 | 11:19 PM
1158's Avatar
I'm hoping he has a turbo/supercharger...
Old Feb 7, 2007 | 04:20 AM
Ari's Avatar
Ari
* B A N N E D *
Default Re: (1158)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1158 &raquo;</TD></TR><TR><TD CLASS="quote">I'm hoping he has a brain...</TD></TR></TABLE>
Fixed.
Old Feb 7, 2007 | 05:15 AM
j_bizach's Avatar
Default Re: (:ari:)
low oil and/or pressure will also put it in limp mode. seen it many times, dumbass starts burning oil next thing hes nows his cars acting shity gets pissed sells it for 1000. I know that cars now mine. topped her off with oil good to go. just saved 2000
Old Feb 7, 2007 | 04:51 PM
yea i do have a FMU ... call me stupid but i currently have a hondata s200 in there with 450 injectors too installed in my car but its is not tune yet.. you think that could be what is killing my car??the tune or the fmu im affraid if i take my car of taking my car to a dyno and teh same thing happens ... cant tune a car that doesnt rev pass 4k ...
Old Feb 7, 2007 | 09:33 PM
iNNovate_DC4's Avatar
gay and proud honda owner
i have the same problem.
Old Feb 8, 2007 | 02:16 PM
Bro if you got hondata and 450's you better have a base map to idle them .Don't mix hondata and the fmu together.Either one or the other.
Old Feb 8, 2007 | 03:49 PM
916jDmDc2's Avatar
i had the same problem but my car would only let it go to 3500 rpm so thats about 64 mph max speed be lucky u can go on the freeway still... but yea check your cells and see what other things come up... might be more then 1 problem
mdoubleg
Sep 24, 2008 02:46 PM
Civic138
10
Jun 27, 2007 02:23 AM
gsr_pimp88
Oct 27, 2006 08:25 PM
turbogsr181
Jul 21, 2006 10:22 PM
riceball777
Jun 4, 2003 09:46 AM
