Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
valve adjustment on r18
Old Feb 6, 2007 | 01:44 PM
ryc555's Avatar
Default valve adjustment on r18
Hey guys im planning to adjust the valve clearance of my car anyone has a diagram?and is it the same as D series on adjusting procedure?thanks a lot.
Modified by ryc555 at 3:06 PM 2/6/2007
Old Feb 6, 2007 | 02:29 PM
TRE_'s Avatar
Default Re: valve adjustment on r18 (ryc555)
How many miles are on the car? I can't fathom why you'd need to be adjusting the valves on such a new car.
Old Feb 6, 2007 | 02:59 PM
ryc555's Avatar
Default Re: valve adjustment on r18 (TRE_)
17,++++ they are a little noisy bro thats why im planning to adjust them.
Old Feb 6, 2007 | 04:57 PM
Caveman74's Avatar
Its probably your injectors ticking. I wouldn't think valves would need adjusting that early
Old Feb 6, 2007 | 06:11 PM
eL's Avatar
eL
If for some reason they did need adjusting, would they cover it under warranty since the car is so new?
Old Feb 6, 2007 | 09:06 PM
24boosted's Avatar
Default Re: (eL)
I HIGHLY doubt you need a valve adjustment that early in the motors life. Unless it was set wrong from the factory or your on nitrous, turbo, or revving to 8.5k in your R18 and even then its questionable.
Modified by 24boosted at 10:18 PM 2/6/2007
Old Feb 7, 2007 | 06:28 AM
jmaz's Avatar
The Honda Tech told me every 30,000 miles.
Old Feb 7, 2007 | 07:52 AM
ryc555's Avatar
oic,thanks a lot for all the input. i guest its the injectors that im hearing inside the car when im driving it.so it is very normal then.
Old Feb 7, 2007 | 08:26 AM
TRE_'s Avatar
Default Re: valve adjustment on r18 (jmaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmaz &raquo;</TD></TR><TR><TD CLASS="quote">The Honda Tech told me every 30,000 miles.</TD></TR></TABLE>
On the older Honda's it was reccomened every 30k but with the new motors Honda does not require them to be adjusted as often.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryc555 &raquo;</TD></TR><TR><TD CLASS="quote">it is very normal then.</TD></TR></TABLE>
Yep.
Old Feb 7, 2007 | 09:27 AM
jmaz's Avatar
SO, how often they should be adjusted?
Old Feb 7, 2007 | 02:35 PM
ryc555's Avatar
if they are noisy
Old Feb 7, 2007 | 02:52 PM
liketofry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryc555 &raquo;</TD></TR><TR><TD CLASS="quote">17,++++ they are a little noisy bro thats why im planning to adjust them.</TD></TR></TABLE> I got about the same milage and at idle my R18 is a quiet as a dead church mouse. Warranty baby
Old Feb 7, 2007 | 03:16 PM
nsxmatt's Avatar
Default Re: valve adjustment on r18 (liketofry)
It's either normal valve noise in colder weather, injectors clicking, or purge valve clicking. Valve adjustment shouldn't need to be adjusted till almost 100k miles.
Old Feb 26, 2007 | 02:19 PM
high_revs's Avatar
im sure they are fine, and honda head will tick after a few thousand miles..its a honda thing
Old Feb 26, 2007 | 02:24 PM
TRE_'s Avatar
Default Re: (h2b_eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">..its a honda thing</TD></TR></TABLE>
You mean injector thing?
Old Feb 26, 2007 | 02:26 PM
high_revs's Avatar
Default Re: (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">
no honda valves tend to tap, no matter how acurattly adjusted they are
Old Feb 26, 2007 | 02:28 PM
TRE_'s Avatar
no honda valves tend to tap, no matter how acurattly adjusted they are</TD></TR></TABLE>
All engines produce some form of noise from the valvetrain... I dont think its specific to Honda's/ any certain mileage.
Old Feb 26, 2007 | 02:32 PM
high_revs's Avatar
Default Re: (TRE_)
All engines produce some form of noise from the valvetrain... I dont think its specific to Honda's/ any certain mileage.</TD></TR></TABLE>
correct, but i've noticed it on honda more then any other manf. could just be coincidince.....but either way, 17,000 miles should make minimal noise.
Old Feb 26, 2007 | 05:42 PM
HondaF1Fanatic's Avatar
My STi's valves were loud as hell, same with the WRX b4 it, it isn't Honda specific.
Jon
Old Feb 26, 2007 | 07:42 PM
high_revs's Avatar
Default Re: (HondaF1Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaF1Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">My STi's valves were loud as hell, same with the WRX b4 it, it isn't Honda specific.
Jon</TD></TR></TABLE>
i didnt say it was honda specific, i said honda valves tend to tap...i work on many kinds of cars, and honda valves are #1 loudest...my friend has an 02 wrx and you cant hear his valves, but in the future who know
Old Mar 5, 2007 | 05:57 PM
Snail Tuning's Avatar
On the older Honda's it was reccomened every 30k but with the new motors Honda does not require them to be adjusted as often.</TD></TR></TABLE>
The 2001 and newer civic only should have the valves adjusted when there noisy, which is almost never. the new civics will almost never need the valves adjusted before 150k. ive never seen a tech adjust valves on a 2001+ civic, and we have 14techs in our shop. i have a blown d17 in my garage, 265k, never had the valves adjusted. and the owner didn't even change the oil regularly. has a spun rod bearing.
laNk_LinK
Mar 3, 2003 03:27 AM
grngsr01
Sep 14, 2002 05:56 AM
mickey513
Feb 19, 2002 10:50 PM
GreenMachine
Jan 14, 2002 04:01 PM
96tegsr
Jun 20, 2001 03:46 AM
