DOHC ZC parts
Old Feb 6, 2007 | 12:41 PM
Lowdreams's Avatar
Default DOHC ZC parts
Where can i find a set of rods, cam gears. And where can i find a stronger set of axles the trany im using is a L3 Trany(the stock crx si trany). And that is if i even need to upgarde them, but i have rebuilt the whole motor top and bottom expect rods, and i also have a t3/t4 turbo on there, and i would rather not snap an axle.
Old Feb 6, 2007 | 12:43 PM
dr_latino999's Avatar
Default Re: DOHC ZC parts (Lowdreams)
Any D-Series rods should do. For the axles, preload the clutch and your axles will last a good long time. Or in shorter terms: Jackassery = Broken Axle
Old Feb 6, 2007 | 01:11 PM
CRX Toad's Avatar
Default Re: DOHC ZC parts (dr_latino999)
^Listen to the man....I mean DR.
Old Feb 7, 2007 | 12:05 PM
Lowdreams's Avatar
Default Re: DOHC ZC parts (CRX Toad)
How much power can the stock crank hold?
Old Feb 7, 2007 | 12:08 PM
More than you'll make.
staticCRX
Jan 23, 2006 05:02 PM
31flavorscivic
Feb 14, 2005 01:08 PM
rasta420
Oct 16, 2003 10:34 AM
beyond-redline
Jan 28, 2003 06:41 PM
fluxpaster
20
Jan 25, 2003 08:46 AM
