installing rear mud flaps
Old Feb 6, 2007 | 12:19 PM
CivicTooner's Avatar
Default installing rear mud flaps
How do I do this? I can't find any info on doing this, I have the fronts installed but the rear is the worst part. Would I have to remove my tires? Any help rocks.
Old Feb 6, 2007 | 12:39 PM
BLUIZE256's Avatar
Default Re: installing rear mud flaps (CivicTooner)
you just line them up and screw them in. . no removing tires. .
Old Feb 6, 2007 | 12:40 PM
B16B_coupe's Avatar
HRD PKR
Default Re: installing rear mud flaps (BLUIZE256)
use a stubby screw driver.. and ur fine..
Old Feb 6, 2007 | 12:42 PM
Eran's Avatar
HT White Ops
Is this for EG or EK? Here's my EK writeup:
Originally Posted by Eran
Here is my own little how-to for everyone installing the Honda Access Splash Guards on their 6th gen Civic. This how-to will work for any body style (coupe, hatch, and sedan), all the holes are in the same place. The only difference is how the rears are shaped (hatches are different from coupes/sedans).
Part Numbers:
96-98 2/4DR - 08P00-S01-101
96-00 3DR - 08P00-S00-100
99-00 2/4DR - 08P00-S01-102
Here's the rundown:
1. Gather all the splash guards, hardware, and tools:
Required Items:
2 Front Splash Guards (L/R)
2 Rear Splash Guards (L/R)
6 Self-Tapping Screws (Front)
6 Self-Tapping Screws (Rear)
4 Spring Nuts
2 Plastic Grommets
Required Tools:
Stubby Screwdriver and/or Offset Screwdriver (Phillips)
Jack and Jackstands
Lug Wrench
Lugnut Key (If Applicable)
2. Turn your wheel toward the side of your car that you are working on. This will allow you adequate room to install the splash guard. Note the location of the screw holes. Remove the screw denoted with the yellow arrow.
*NOTE* - If you still have your fender liner in place, there will be screws in each hole. If your kit did not come with the front hardware, reuse all these screws.
3. Gather three of your six self-tapping screws.
4. Mount up the splash guard and install the screws in the earlier noted holes. Make sure you you flush the splash guard up with the side skirt.
5. Repeat steps 2-4 on the opposite side of the car. Step back and admire your work. This is a good time to get a beer before starting on the rears. :lol:
6. Gather one rear splash guard, three self-tapping screws, two spring nuts, and a plastic grommet.
7. Jack up the side of the car you are working on. Secure with a jackstand.
**Never work under your car using only the jack as a support. This is very dangerous, not to mention stupid.**
8. Remove your rear wheel (unless you've got tiny hands and are using a really small offset screwdriver).
9. Push the plastic grommet into the square hole on the rear of the fender well. Slide the spring nuts over the very top and very bottom screw indentations on the bumper. With your screwdriver and a little bit of force, pre-thread the screws into the bumper. Remove the screws.
10. Mount up the rear splash guard, making sure the bottom lip of the bumper is in the channel groove.
11. Install the three self-tapping screws. Leave the bottom one slightly loose. Holding the splash guard by the bottom, press upward to flush it up with the bottom of the bumper. Tighten the bottom screw.
Mount your wheel back on the hub, and propperly torque your lugnuts. Jack the car up, remove the jackstand, and lower the car back onto the ground.
12. Repeat steps 6-11 on the opposite side of the car.
Congratulations, you have installed your factory splash guards!
Old Feb 6, 2007 | 12:43 PM
tanabe's Avatar
Remove the tire if it's easier for you to screw them on
Old Feb 6, 2007 | 03:39 PM
BlueIntegraBoy's Avatar
For ease, I jacked up the rear when I installed mine. There was no need to remove the wheel.
Old Jan 6, 2011 | 09:10 PM
Chelios's Avatar
were can i get the honda del sol fender SCREW GROMMET
Old Dec 29, 2011 | 06:19 AM
PhantomPharter's Avatar
awesome write up. thank you.
tianporn
Apr 2, 2015 09:49 AM
2000CivicCX
Apr 22, 2011 05:27 AM
Pabs626
Nov 16, 2008 03:40 PM
oneiro
Nov 4, 2008 03:35 PM
d'sb16a2
Apr 19, 2007 04:43 PM
