Questions on JDM GSR engine swap
Old Feb 6, 2007 | 12:09 PM
matsgsr's Avatar
Default Questions on JDM GSR engine swap
I recently purchased a JDM GSR motor and tranny. Once i got the motor and started looking to see how it was going to go together i noticed the wiring harness is backwards on my JDM motor due to the driver on the other side of the car. I figured i could just use my wiring harness from my integra, except there is one problem, i have an LS integra, not a gsr. My LS harness does not have the VTEC solenoid plugs. Is there any way to splice in the plugs from the JDM motor to my LS, or do i have to break down and spend tons of money on a USDM GSR harness. Any comments would be really helpful. Thanks.
Matt
Old Feb 6, 2007 | 12:12 PM
lVlemphizStylez's Avatar
Default Re: Questions on JDM GSR engine swap (matsgsr)
you run hardlines off the solenoid to the ecu itself...This is what I did, worked like a charm.....
Old Feb 6, 2007 | 12:31 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you're good with wiring you could probably de-pin the wires from the JDM harness ECU plugs and add them into your OEM harness, making it look completely stock.
<-- stickler for not having aftermarket wires running all over the place
Old Feb 6, 2007 | 12:35 PM
Default Re: (PatrickGSR94)
eh its like one wire though...not huge deal
LOVEthatDC2
Jul 26, 2009 11:49 AM
97_hatch
Jun 11, 2008 10:28 PM
this1drumma
Feb 13, 2008 04:04 AM
duggy
Aug 25, 2005 02:40 PM
