transmission fit?
Old Feb 6, 2007 | 10:52 AM
1kleenef's Avatar
Default transmission fit?
i was wondering if an 88 crx si tranny will fit in my 91 sedan with a d16z6 swap im going to b buying it this wkend ne help greatly appreciated.
Old Feb 6, 2007 | 10:53 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: transmission fit? (1kleenef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1kleenef &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if an 88 crx si tranny will fit in my 91 sedan with a d16z6 swap im going to b buying it this wkend ne help greatly appreciated. </TD></TR></TABLE>
Only if you use a 88 flywheel/clutch combo. That was the oddball transmission of this generation.
Old Feb 6, 2007 | 11:01 AM
1kleenef's Avatar
Default Re: transmission fit? (wiZCo)
is it hard to mate to a d16z6 though
Old Feb 6, 2007 | 11:03 AM
Ahknodd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
Only if you use a 88 flywheel/clutch combo. That was the oddball transmission of this generation.</TD></TR></TABLE>
The 88 clutch (input shaft on tranny) uses a 21 spline where as the 89-91s (and on up) use a 20 spline configuration. So you will need an 88 clutch. The flywheel is also smaller (I think by 12mm, 200 vs. 212 in the 89-91). So you're best bet is to get an 88 clutch and flywheel combo like wiZCo said. I think you can us a 89-91 flywheel and pressure plate, but use the 88 disc. I think ACT has a kit for this set up. I'm not 100% sure though.
Good luck, how do you like the Z6?
Later
Old Feb 6, 2007 | 11:04 AM
Ahknodd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1kleenef &raquo;</TD></TR><TR><TD CLASS="quote">is it hard to mate to a d16z6 though</TD></TR></TABLE>
How so?
Old Feb 6, 2007 | 11:05 AM
1kleenef's Avatar
Default Re: transmission fit? (Ahknodd)
i love the z6 with a 7500 redline it pulls on most things around here like a preppy boys ls last nite just looking for a new tranny solution.
Old Feb 6, 2007 | 06:55 PM
Ahknodd's Avatar
I didn't know the Z6 went to 7500. Sweet ****. I'm putting a y8 head on my d15B with a P28 in my 91 hatch, so that's going to be fun.
Why are you looking for a new tranny? Is your other one bad or grinding? Or is it the ever so gay 4 speed? Anyway, if you good at doing engine work, manual tranny work isn't hard. I've ripped apart a few and have put em back together with no problems. So if you want you could just swap out that 88 input shaft and put in one from a 89-91, that way you won't need to get an 88's clutch.
Just a thought.
Old Feb 6, 2007 | 11:21 PM
1kleenef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahknodd &raquo;</TD></TR><TR><TD CLASS="quote">I didn't know the Z6 went to 7500. Sweet ****. I'm putting a y8 head on my d15B with a P28 in my 91 hatch, so that's going to be fun.
Just a thought.</TD></TR></TABLE>
i actually have a chipped ecu running crome that enables me to reach those rpms but ne way my car has been making this popping noise in the front end and i haven't been able to figure it out so maybe axles or motor mounts but neither one. so i take it to the guy who always works on my car and he tells me to push the clutch in and slowly let it out i do and when i did you can hear a slight grind/whine coming from the tranny so now im either looking for an l3 si tranny or swap to hydro and put in a z6 tranny
Old Feb 6, 2007 | 11:31 PM
2poor2tune's Avatar
i have an si tranny for sale. out of a 90 civic si hatch. lmk if you want it threw pm. thanks. and any cable d series tranny will fit just the same as the one you have in there right now
Old Feb 7, 2007 | 10:43 AM
wiZCo's Avatar
Stouts 'n' Scotch
Popping noise is probably a motor mount. Try running syncromesh in there to see if it solves your grind issue.
Old Feb 8, 2007 | 07:40 AM
1kleenef's Avatar
its not a motor mount already checked and what is syncromesh and where do i find it.
Old Feb 8, 2007 | 08:03 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1kleenef &raquo;</TD></TR><TR><TD CLASS="quote">its not a motor mount already checked and what is syncromesh and where do i find it.</TD></TR></TABLE>
Who checked... you or your mechanic? I'm still betting on motor mount. Anyways, you can find GM syncromesh at NAPA or lots of other parts stores.
Old Feb 8, 2007 | 08:18 AM
1kleenef's Avatar
my mechanic he did the whole ebrake and let the clutch out so he could put torque on them and the didn't make the sound and do i just pour this stuff in my tranny with the tranny fluid.
crxricer66
Dec 23, 2007 01:27 PM
fresnodx
Sep 8, 2004 08:31 PM
firstgenrex
Jan 25, 2004 10:23 AM
Krayzielix
Dec 7, 2003 03:44 PM
TKL
Feb 15, 2003 02:37 PM
