throttle body
will a 2.3 litre mustang throttle body fit onto my dpfi????.........if not im lookin for the BIGGEST throttle body i could use any help would b great
...thanks all
FAST CIVIC #46
...thanks allFAST CIVIC #46
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic46 »</TD></TR><TR><TD CLASS="quote">will a 2.3 litre mustang throttle body fit onto my dpfi????.........if not im lookin for the BIGGEST throttle body i could use any help would b great
...thanks all
FAST CIVIC #46</TD></TR></TABLE>
fast civic huh? why do you wish to acquire the largest throttlebody possible? please, do a mpfi swap, then go from there.
this function will help more than a cavernous throttlebody. <FONT COLOR="red"><u>Search</u></FONT> MPFI SWAP.
...thanks allFAST CIVIC #46</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">
this function will help more than a cavernous throttlebody. <FONT COLOR="red"><u>Search</u></FONT> MPFI SWAP. </TD></TR></TABLE>
MPFI Swap!!!
DPFI is gay and for homos only! I used to have one. A bigger throttle body for your DPFI will not do much if anything at all. That system is a throttle body fuel injection system and is made for fuel economy. NOT POWER!
Go MPFI, worth it all the way.
MPFI Swap!!!DPFI is gay and for homos only! I used to have one. A bigger throttle body for your DPFI will not do much if anything at all. That system is a throttle body fuel injection system and is made for fuel economy. NOT POWER!
unfortunatly my civic is a stock car at a local dirt track and i cant change it to the mpfi so if u would know the biggest throttle body that would b excellent
take the 4 screws off of the top of your dpfi manifold/intake.
you'll see a screen in there and a little L shaped metal piece.
ive actually seen people take off the complete dpfi plastic stuff off, and mount an intake pipe directly to the throttle body.
That's how the 7th gen intakes are. The manifolds are similar to the dpfi in our cars. So if you can get a hold of an intake for cheap from a 01-05 civic then you've got an intake.
I would go with taking out the restrictions and possibly boring out the throttle body. I doubt there is any throttle body that would bolt on to the dpfi's manifold.
Too bad you didn't get an si and run it in your stock class, then you'd have the 1.6L (d16a6) and the mpfi... you'd be a bit quicker. Oh well. Good luck
joy123
Jan 3, 2008 10:01 AM
