vtec solenoid
Old Feb 6, 2007 | 10:45 AM
4th-gen-civic's Avatar
Default vtec solenoid
i got a 1st gen b16. the gasket that is between the motor and the oil pressure sensor is cracked anyone know what car to order this for? 93 gsr?
Old Feb 6, 2007 | 11:13 AM
Ahknodd's Avatar
Default Re: vtec solenoid (4th-gen-civic)
by 1st gen b16 do you mean b16a? I believe those are JDM motors only. But they may have been in the Del Sol Vtecs, which are 92 and up. (3 GSR is a B17, not B16) I would ask in the Tech forum or in the Integra forums.
I would think that the part may be universial with all b motors though. I'd go to the dealership or look online for a picture of the part with the part numbers and see if the part on a B18 Integra is the same or even a 99-00 Civic Si.
Good luck, hope i Helped.
Later
Old Feb 6, 2007 | 11:29 AM
STREETWERKZ's Avatar
you can order it from honda. try a 99-00 honda civic SI or a 92-95 civic EX or SI
its called a spool valve gasket. (vtec solenoid gasket) its the same between any VTEC motor.
it's number 12 in the diagram.
part number: 15825-P08-005
Jason Nucom
Nov 27, 2012 06:23 PM
InTheLBC20
Dec 31, 2010 01:00 PM
Reelizmpro
Nov 28, 2004 10:43 PM
JDM-Vic
Apr 28, 2004 03:53 PM
type Gendy
Apr 2, 2003 02:17 PM
