ex dizzy = si dizzy correct?
Old Feb 6, 2007 | 10:30 AM
AJxr's Avatar
Default ex dizzy = si dizzy correct?
searched and couldnt get a direct answer. doing an mpfi swap on a friends 91 dx hatch, theres a 90-91 ex 4dr at the pick n pull and i was hoping that the crank angle sensor and the distributor will work for this swap. can anyone confirm?
Old Feb 6, 2007 | 10:31 AM
jlicrx's Avatar
Default Re: ex dizzy = si dizzy correct? (AJxr)
88-91 Si, 88-91 HF and 90-91 EX distributors will all work - the crank sensor is in the distributor
Old Feb 6, 2007 | 10:36 AM
AJxr's Avatar
Default Re: ex dizzy = si dizzy correct? (jlicrx)
are you 100% sure the hf dist will work? just wondering because i have one laying around
Old Feb 6, 2007 | 10:37 AM
jlicrx's Avatar
i wouldn't have said it if it wasn't true
Old Feb 6, 2007 | 10:38 AM
dr_latino999's Avatar
HF distributor will work, it's MPFI, OBD-0, and the distributor flange is the same, so by conclusion, it works
crxnj's Avatar
yeah it will work fine
fitbkeco
Aug 2, 2013 01:04 PM
white90crxhf
Feb 16, 2010 11:13 PM
Badass240SX
Dec 5, 2004 08:37 PM
Donkey85
Jun 2, 2003 08:40 PM
turbohf
Feb 22, 2003 05:06 PM
