Ticking from B18C1 head
I have a DB8 with a low km B18C1 from a 00 gsr. There is an annoying ticking coming from the valve train i believe. There ticking gets faster as I accelerate. I thought maybe it need a valve adjustment, but that did not work.
Any ideas what I should check for?
Modified by mugenboi at 9:39 AM 4/20/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok »</TD></TR><TR><TD CLASS="quote">check compression... possible bent valves...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azn Kenny »</TD></TR><TR><TD CLASS="quote">Yeah do a valve lash adjustment and check your oil level.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenboi »</TD></TR><TR><TD CLASS="quote">Compression is good!
The ticking goes away when in vtec. So maybe it is the valves?</TD></TR></TABLE>
ticking is either valvelash needs to be adjusted or its the injector's ur hearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R »</TD></TR><TR><TD CLASS="quote">ticking is either valvelash needs to be adjusted or its the injector's ur hearing.</TD></TR></TABLE>
It is VERY common for Honda injectors to be loud. Not saying it is definately your injectors, but I wouldn't be surprised. There have also been a ton of people who thought they did the adjustment correctly, but didn't for one reason or another. Also not trying to say you did it wrong, but consider it a possibility.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jumai182 »</TD></TR><TR><TD CLASS="quote">Mines has a ticking too. I almost mistook it for pinging because of gas reasons. Could it be a valve spring or something?
(Area I hear the ticking)</TD></TR></TABLE>
Yeah it sounds like the noise is coming from the top right corner aswhile. I thought the valvelash needed to be adjusted, but it only helps alittle.
This sounds makes my motor sound like a old car. Its really annoying. I just want to pin point thats causing it so that i can fix it.
Maybe you could narrow it down with a good ol fashioned low-tech inspection. What I mean is either get an automotive stethoscope, or use a long screwdriver held up to your ear (the plastic end, not the metal end
to pin-point the sound.
It's the lost motion assemblies. When not in vtec, the third rocker (the vtec rocker) is not being used and will bounce around and tick if the spring is worn. Once in vtec, the rocker gets used and doesn't bounce around so the noise stops. I can't believe how many people suggested valve adjustment when you said you did that and it didn't help... not to mention that about 10 people said the same thing as if you didn't read it the first time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R »</TD></TR><TR><TD CLASS="quote">It's the lost motion assemblies. When not in vtec, the third rocker (the vtec rocker) is not being used and will bounce around and tick if the spring is worn. Once in vtec, the rocker gets used and doesn't bounce around so the noise stops. I can't believe how many people suggested valve adjustment when you said you did that and it didn't help... not to mention that about 10 people said the same thing as if you didn't read it the first time.
Thanks Hatch-R... thats very informative.
Now, how should I got about replacing the LMAs? i think ive read that ppl have used prelude LMA (h22).
</TD></TR></TABLE>Thanks Hatch-R... thats very informative.
It shouldn't be too hard. Basically take out the cams and then if I remember right, you just pull the LMAs up and they'll come off. People do the ITR/Prelude LMA mod because I think they're shorter, which bigger cams need if they're big enough, and so that the LMAs don't bind when used with the big cam (you need to use washers with the Prelude ones). Basically just do a search on H-T and there's a bunch of info about this stuff.
