Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Turbo Questions
Old Feb 6, 2007 | 10:03 AM
The7thG's Avatar
Default Turbo Questions
I just had a couple of random questions that have been on my mind. Anyone with knowledge on anything your help would be appreciated.
1. I recently read that a fuel return line sends unused fuel back to the tank. I also heard that it basically is a reservoir that stores fuel so your lines dont dry out at WOT, is it both?
2. A turbo with an internal wastegate, can it be adjusted, not just up but down. I was thinking about a slightly big turbo but im not ready for all the power yet?
3. While observing some turbo kits I noticed some have an extra pipe on the exhaust manifold for the turbo and other it appears all of the exhaust is sent through the turbo. I was just curious as to the performance differences.
4. Would a fuel pressure regulator work as a cheap way to use a turbo with the stock d17a2 fuel systems?
5.http://cgi.ebay.com/ebaymotors/01-05...spagenameZWDVW
Not sure if that link will work but if it does you will see a turbo kit for a d17 for $1000. Does anyone know of any reasons why this would not be a bargain.
Old Feb 6, 2007 | 12:08 PM
AR_motorsports's Avatar
Default Re: Turbo Questions (The7thG)
If I am not mistaken it just returns back to the tank and as for a fuel pressure regulator I don't think it will actually work on the stock d17a2 fuel system without bypassing our in tank regulator. And as for my personal opinion on turbo size I would say on a d17 setup go with a smaller turbo spools quicker and when you want more just crank up the boost on your wastegate. If you want you can the the forced induction forum I have a post of the set up I'm building its under "D17a2 turbo project" price tag right now is around $2,200 DIY
Old Feb 6, 2007 | 01:28 PM
Boost_Junkie's Avatar
just please dont buy that ebay ****...
Old Feb 6, 2007 | 03:39 PM
Vantage's Avatar
Default Re: (Boost_Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_Junkie &raquo;</TD></TR><TR><TD CLASS="quote">just please dont buy that ebay ****...</TD></TR></TABLE>
^ thats the best advice any1 can give.
And no u cant use a fuel pressure regulator. That is what having return fuel systems do away with.
Old Feb 6, 2007 | 06:13 PM
The7thG's Avatar
Default Re: (Vantage)
ok cool thanks for the help guys. yeah it didnt seem like a good idea but im getting a little impatient for a power adder.
Old Feb 6, 2007 | 09:05 PM
Vantage's Avatar
hit up dezod.com, It will cost u an arm and a leg for their turbo kit, but it is by far the safest and most well put together kit on the market.
Old Feb 7, 2007 | 11:01 AM
blumpfish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The7thG &raquo;</TD></TR><TR><TD CLASS="quote">
i think you can adjust the wastegate iether way depending on the stiffness of the spring in it
if you use kpro, you can use boost by gear 5lbs in 1st gear etc. for traction issues
i would highly recommend not going with any ebay stuff
Old Feb 7, 2007 | 11:09 AM
Miracle's Avatar
Default Re: Turbo Questions (blumpfish)
We don't have K-Pro on our cars..... they didn't come with a K.
Old Feb 7, 2007 | 11:11 AM
blumpfish's Avatar
Default Re: Turbo Questions (Miracle)
well, some did.. i was assuming he was talkin about an EP i just reread his post and i see its a D series
Old Feb 7, 2007 | 11:22 AM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blumpfish &raquo;</TD></TR><TR><TD CLASS="quote">well, some did.. i was assuming he was talkin about an EP i just reread his post and i see its a D series </TD></TR></TABLE>
Only the EP3 came with a K-series engine, which wouldn't be in this forum to begin with. It'd be in the DC5 RSX/Civic EP3 forum.
Old Feb 7, 2007 | 02:52 PM
The7thG's Avatar
Being able to adjust boost by gear sounds like a very interesting feature. I definitely want a EMS but the prices are pretty depressing. What r the major setbacks of a piggyback as compared to stand alone. Any info on the turbo manifold question would also help. thanks
Old Feb 7, 2007 | 03:16 PM
OSK Automotive's Avatar
Do you have a pic of the exhaust manifold you're talking about, I can't picture it.
Modified by MisterFrankieJ at 7:29 PM 2/7/2007
Old Feb 7, 2007 | 06:50 PM
skipbarber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The7thG &raquo;</TD></TR><TR><TD CLASS="quote">Being able to adjust boost by gear sounds like a very interesting feature. I definitely want a EMS but the prices are pretty depressing. What r the major setbacks of a piggyback as compared to stand alone. Any info on the turbo manifold question would also help. thanks</TD></TR></TABLE>
they both have drawbacks, the ems is GREAT for tuning, but disables all your emissions devices including the check engine light and several other obd2 features. piggy backs allow you to retain all of that, but struggle with partial throttle boost because any changes it tries to make, the stock ecu compensates and pulls fuel where the piggy back tries to add it. but hands down the ems alone would yield great results. and i agree with everyone here, you can buy name brand components on ebay when you find a good deal, but those 'kits' are more trouble than it's worth.
Old Feb 7, 2007 | 07:20 PM
Default Re: Turbo Questions (skipbarber)
why not just do what I plan on doing convert to obd1 and use a chipped p28 ecu tuned for your set up withe crome or uberdata?
integrawow
May 12, 2007 07:13 PM
89crxsleeper
Nov 28, 2005 07:55 PM
dxlst
Mar 30, 2004 11:30 PM
bigfattom
Jan 15, 2002 06:22 PM
