Valve angle in F and H series head?
Are the valve angles different for H22 DOHC and F22 SOHC heads? I know the H22 valves are bigger, but if the angle is the same then a H22 piston would have adequite reliefs for F valves. ?
I'm not positive, but pretty sure the angles are indeed different, but H22 pistons with an F22 head? I think boring an F-block to 87mm is pushing it almost to its limit. What are you trying to do?
street_ride14
Sep 27, 2010 09:55 AM
topsekret
May 12, 2005 09:47 AM
