Problem with Turn Signal and S2000 Sidemarker EG's
Problem
I just got some S2000 Sidemarkers for my EG. After doing all the wiring that I followed from different searches on how to wire them they still arent working like I want them to.
I wanted them to stay on at all times when the corners lights are activated as well as headlights. NOW when i turn my head light on my Right and left turn signal on my dash stay on and outside the sidemarkers are on as supposed to and so are the corners but in the back the yellow turn signal lights are frozen stuck on yellow. and when i turn off the headlights and corners the signal stops being stuck BUT when i signal in any direction my turn signals work properly but the brake lights and license plate lights all blink adjacently. If i take off my sidemarker wiring everything is normal. So how do i WIIRE S2000 Sidemarkers to a EG properly. They have 3 wires each sidemarker Two green and one Black (ground i guess) So how do i wire it so everything works normal. Do i have to wire 2 or 3 wires and does it need a ground?
2 green wires? you should have one green and one red. i don't remeber which is for which, but i do know that it can one or the other not both.
it's either used for turning (which that's what it was intended for), or on with the corner lights. that's it.
WTF? That was hard to read.
The correct way to wire the sidemarkers is to make them blink with your turn signals. From what I am reading, you want them constant. To do this, take the green wire from your turn signal socket and splice it into the red wire of the turn signal. Black for black.
Integra boy what you just wrote was hard to comprehend. Are you saying this:
Splice the Turn signal red Wire to the Green Turn Signal wire OR Splice the Sidemarker wire to the Wire you stated and the negative to negative obviously.
I WANT MY SIDEMARKERS TO:
Stay on when corners are on and blink as well when corners blink whats the correct wiring?
Ok thanks Integra boy for clearing things up. So this wiring that you posted will keep my Sidemarker on constant and blink when turn signal is put on correct? Thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 »</TD></TR><TR><TD CLASS="quote">Ok thanks Integra boy for clearing things up. So this wiring that you posted will keep my Sidemarker on constant and blink when turn signal is put on correct? Thanks again</TD></TR></TABLE>
According to another post. I wired my sidemarkers to work with the turn signals only.
fryman
12
Nov 7, 2011 09:42 AM
EF_World
14
Oct 12, 2010 07:06 PM
BadassEFdriver
Sep 1, 2010 03:21 AM
