Heater Heat Problem
Old Feb 6, 2007 | 07:50 AM
jdadams12's Avatar
Default Heater Heat Problem
Hello,
I have a 1992 Accord LX with about 290-300K on it. The heat won't blow hot unless the engine it at some kind of RPM (driving). When driving, the heat is very nice.
I am not going to take the heater core out, but I was wondering if there is anything else that I can do. Any ideas?
Thanks.
Old Feb 6, 2007 | 08:02 AM
JimBlake's Avatar
Default Re: Heater Heat Problem (jdadams12)
Sounds like it could be a stuck-open thermostat. How does the temperature gauge behave?
Old Feb 6, 2007 | 12:03 PM
Sam_J's Avatar
^ Most likely a stuck open thermostat.. I had the same problem and a new t-stat fixed it...
Old Feb 12, 2007 | 07:03 AM
jdadams12's Avatar
Default Re: (Sam_J)
Thermostat is working fine. Heat guage is fine (at the same level it is always at) and the cooling system is working properly - it waits to open and then floods the radiator with hot water. I was wondering if it could be a somewhat clogged up heater coil and if there was any junk that you could run through it to unclog it.
This is not really that big of a deal since I am almost always moving, but it is somewhat of a pain when I am stuck in traffic.
helldriver88
Jan 26, 2008 10:33 PM
TheSSG
Dec 6, 2005 02:00 PM
ZC88CRX
Sep 2, 2003 09:57 AM
