cleaning headlights
Old Feb 6, 2007 | 07:30 AM
tx6stringer's Avatar
Default cleaning headlights
ive seen a lot of methods for cleaning headlights but i was wonderin if anyone knows the best cheap and easy way to get the job done?
Old Feb 6, 2007 | 07:32 AM
Eran's Avatar
HT White Ops
I've never seen a method that costs more than $20 in parts.
Various grits of sandpaper, water, and a rubbing compound, that's about as cheap as it gets.
Old Feb 6, 2007 | 08:18 AM
allricedout's Avatar
a high speed buffer with a pad and compound, and if they need more help use some like 1000-1500 grit paper.
Old Feb 6, 2007 | 09:05 AM
Default Re: (allricedout)
does the majority of the yellow fog build up on the outside or the inside of the lens? I ask this to ask if it is possible to clean them without removing the lenses because it gets to be a hassle with the bolt under the fender??
Old Feb 6, 2007 | 09:06 AM
Eran's Avatar
HT White Ops
Default Re: (tx6stringer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx6stringer &raquo;</TD></TR><TR><TD CLASS="quote">does the majority of the yellow fog build up on the outside or the inside of the lens? I ask this to ask if it is possible to clean them without removing the lenses because it gets to be a hassle with the bolt under the fender??</TD></TR></TABLE>
Outside.
Old Feb 6, 2007 | 09:09 AM
Default Re: (Eran)
so doing the cleaning without taking the lens off is reasonable?
Old Feb 6, 2007 | 09:10 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx6stringer &raquo;</TD></TR><TR><TD CLASS="quote">so doing the cleaning without taking the lens off is reasonable?</TD></TR></TABLE>
Yep, just get some newspaper and blue painters tape and mask off the area around the headlight
Old Feb 6, 2007 | 09:17 AM
Default Re: (Eran)
sounds good. thank yall. ill try it today.
bpkmrtoes's Avatar
Default Re: (Eran)
i'd seriously just grab the kit available at pepboys and other stores. it's 7-12 bucks comes with everything you need and some nice directions. works great
Old Feb 8, 2007 | 07:30 PM
Default Re: (bpkmrtoes)
Alright I found a real quick and easy solution that works. I bought a plastic cleaner called Plastx made for headlights for 5 bucks at Wal Mart and picked up a little terry cloth applicator for 1 dollar. scrubbed the lights and the cloudiness came right off. Anyone wanting to clean their headlights Plastx works great.
Old Feb 8, 2007 | 07:32 PM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx6stringer &raquo;</TD></TR><TR><TD CLASS="quote">Alright I found a real quick and easy solution that works. I bought a plastic cleaner called Plastx made for headlights for 5 bucks at Wal Mart and picked up a little terry cloth applicator for 1 dollar. scrubbed the lights and the cloudiness came right off. Anyone wanting to clean their headlights Plastx works great.</TD></TR></TABLE>
I did the exact same thing. It's not crystal clear, but as close as you're going to get for $6
Old Feb 8, 2007 | 07:33 PM
Eran's Avatar
HT White Ops
Meguiar's PlastX works for very minor fog. For as bad as 6th gen civics get, PlastX hardly ever works. I'm glad it worked out for you, but trust me, it's been tried again and again, without results.
Old Feb 8, 2007 | 07:34 PM
Ek Forever y0!
Default Re: (Eran)
so would hand sanding it work okay?
Old Feb 8, 2007 | 07:39 PM
1000-1500 grit.... with a high speed buffer and compound (to glaze and polish them to a brand new headlight look)... esp. if you have those annoying rock divits.
Old Feb 8, 2007 | 07:54 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">so would hand sanding it work okay?</TD></TR></TABLE>
Old Feb 8, 2007 | 07:55 PM
Eran's Avatar
HT White Ops
Default Re: (ek forever guy)
Yeah, I wouldn't use a power sander on them. Just a buffer to apply the polish and glaze.
Old Feb 8, 2007 | 08:07 PM
Ek Forever y0!
Default Re: (Eran)
Am I not wording it right?
Old Feb 8, 2007 | 08:08 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Am I not wording it right?</TD></TR></TABLE>
I just answered your question, homie. Sand by hand, buff with power.
Old Feb 8, 2007 | 08:15 PM
WongFeihung's Avatar
Default Re: (Eran)
I've used Toothpaste before. (on my ej8)
Old Feb 8, 2007 | 10:39 PM
Tjames8864's Avatar
Default Re: (Eran)
def. make sure you WETSAND it....
Old Feb 8, 2007 | 10:40 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tjames8864 &raquo;</TD></TR><TR><TD CLASS="quote">def. make sure you WETSAND it....</TD></TR></TABLE>
Soapy water ftw.
Old Feb 8, 2007 | 11:13 PM
2wir3d's Avatar
Default Re: (Eran)
do you guys have any pics of the plastx done after it was put on the car?
Old Feb 8, 2007 | 11:14 PM
Eran's Avatar
HT White Ops
Default Re: (2wir3d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wir3d &raquo;</TD></TR><TR><TD CLASS="quote">do you guys have any pics of the plastx done after it was put on the car?</TD></TR></TABLE>
Like I said, in most cases, PlastX doesn't help much.
Old Feb 9, 2007 | 12:19 AM
Pr0ject93hb's Avatar
Default Re: (WongFeihung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WongFeihung &raquo;</TD></TR><TR><TD CLASS="quote">I've used Toothpaste before. (on my ej8) </TD></TR></TABLE>
i dunno about head lights
but toothpaste shines my teeth...
Old Feb 9, 2007 | 06:03 AM
Ek Forever y0!
Default Re: (Pr0ject93hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0ject93hb &raquo;</TD></TR><TR><TD CLASS="quote">
but toothpaste shines my teeth...</TD></TR></TABLE>
Clean teeth FTMFW
