b16 boosted
i have a question i have a b16 in my 91 crx turbo and i want to know what radiatior i should use due to clearance issues. Or a good turbo manifold that will clear the hood. Thanks
95' and up neon radiator ... eg radiator is fine if you want a gansta lean, i have a eg rad and its jsut to large unless you get an aftermarket subframe
good for now though
good for now though
I notched my lower core support a little and made a custom bracket to make my eg sit straight up and down! Easy process but from what I have heard the neon radiator is the way to go!
The Neon radiator fits so well, it's amazing. Whoever first did this is a genius. It also frees up a lot of room since you don't have to lean it back like the EG radiator. Just need to remember that you need to use the 95-99 non-A/C radiator.
is there any aftermarket ones i can buy like aluminum ones? also im probably buying a turbo manifold that looks like ram horns with a t3/t4 precision turbo.- i need to know if this will all fit and clear the hood
dingusjt
May 9, 2004 09:32 PM
