ITR Front Strut Bar on an EG -- need an adaptor plate?
Old Feb 5, 2007 | 09:08 PM
JMelt4's Avatar
Default ITR Front Strut Bar on an EG -- need an adaptor plate?
I just picked up a ITR Front Strut Bar for my EG, but when I went to bolt it down, the holes on the bar don't line up with the strut towers....not even close! So do I need some kind of adaptor or special piece to make this bar fit? thanks!
It's this type of bar:
Old Feb 5, 2007 | 09:14 PM
Eran's Avatar
HT White Ops
There's no adapter plate. It doesn't go to the bolts on the strut tower. There's two "dimples" on the fenderwell near the shock tower, and on cars equipped with a strut tower bar, there are two studs welded in place there. Just buy some metric grade 10 bolts (or SAE grade 8), drill a hole in through your fender, put some Rustoleum paint around the holes. Then bolt it down.
Here's an example, my EJ6 with a DC2 strut bar.
Old Feb 5, 2007 | 09:18 PM
JMelt4's Avatar
Default Re: (Eran)
I want to eat off your valve cover! CLEAN!
Nice, thanks for the tips! I never would have figured that out.
Old Feb 5, 2007 | 09:19 PM
Eran's Avatar
HT White Ops
Default Re: (JMelt4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMelt4 &raquo;</TD></TR><TR><TD CLASS="quote">I want to eat off your valve cover! CLEAN!
Nice, thanks for the tips! I never would have figured that out. </TD></TR></TABLE>
No problem
Old Feb 5, 2007 | 09:54 PM
BlueIntegraBoy's Avatar
Default Re: ITR Front Strut Bar on an EG -- need an adaptor plate? (JMelt4)
Here's my car... As Eran said... but you don't need to drill holes in an EG.
Old Feb 5, 2007 | 09:55 PM
Eran's Avatar
HT White Ops
Default Re: ITR Front Strut Bar on an EG -- need an adaptor plate? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Here's my car... As Eran said... but you don't need to drill holes in an EG.
You guys have the studs already?
Suckass.
Old Feb 5, 2007 | 09:59 PM
Default Re: ITR Front Strut Bar on an EG -- need an adaptor plate? (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Suckass.</TD></TR></TABLE>
No, they are bolts I bought at a hardware store. They have rubber caps that cover the holes you feed the bolts through, no dimples.
Eran's Avatar
HT White Ops
No, they are bolts I bought at a hardware store. They have rubber caps that cover the holes you feed the bolts through, no dimples.</TD></TR></TABLE>
Ah. So your car just comes with holes ....
Old Feb 5, 2007 | 10:01 PM
Ah. So your car just comes with holes .... </TD></TR></TABLE>
Yup
Old Feb 5, 2007 | 10:41 PM
graveltravel2's Avatar
or you can buy a OEM JDM sirII civic 92-95 strut bar.
hmotorsonline has them in stock. and they bolt right on with no problems!!!
Old Feb 5, 2007 | 10:43 PM
Default Re: (graveltravel2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel2 &raquo;</TD></TR><TR><TD CLASS="quote">or you can buy a OEM JDM sirII civic 92-95 strut bar.
hmotorsonline has them in stock. and they bolt right on with no problems!!!</TD></TR></TABLE>
The SiR and ITR bars bolt into the same location.
Old Feb 6, 2007 | 05:07 AM
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">The SiR and ITR bars bolt into the same location.</TD></TR></TABLE>
i was told that you have to modify the itr and grs bars.
Old Feb 6, 2007 | 05:45 AM
95ProjectEJ1's Avatar
Default Re: (Eran)
Sorry this is off topic and not to be a post *****, but that is one clean *** engine bay you have there Eran.
Old Feb 6, 2007 | 06:30 AM
EMoneR's Avatar
Default Re: (95ProjectEJ1)
My 94 dx coupe didnt have the rubber plugs so. that means I had to drill.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Here's my car... As Eran said... but you don't need to drill holes in an EG.
Just FYI
Old Feb 6, 2007 | 07:27 AM
jboy08's Avatar
Default Re: (JDMmeansFASTER)
not 100% about this, but i think si's had the holes pre-drilled. like they said, just get the bolts/studs/whatever, slide them from tire well and you'll be fine.
btw, i had a gsr strut bar on my eh3...
Old Feb 6, 2007 | 07:35 AM
philosofy1's Avatar
Default Re: (jboy08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jboy08 &raquo;</TD></TR><TR><TD CLASS="quote">not 100% about this, but i think si's had the holes pre-drilled. like they said, just get the bolts/studs/whatever, slide them from tire well and you'll be fine.
btw, i had a gsr strut bar on my eh3... </TD></TR></TABLE>
Yup</TD></TR></TABLE>
NOPE, if you have a civic from 92-93 then yes they came with the holes already and has caps which need to be removed if you want to mount a oem bar on top.
94-95 did not come with this and the holes need to be drilled.
i was told that you have to modify the itr and grs bars. </TD></TR></TABLE>
WTF? who ever told you that was lieing, don't ever listen to them again, EVER!
Old Feb 6, 2007 | 07:41 AM
Dilly's Avatar
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">NOPE, if you have a civic from 92-93 then yes they came with the holes already and has caps which need to be removed if you want to mount a oem bar on top.94-95 did not come with this and the holes need to be drilled.
ahhh... it all makes sense now. haha. i started reading towards the bottom and i see some people are saying you gotta drill their own holes. and im like what the hells goin on here? haha. cause i had holes in my hatch. thought i was freakin out for a minute.
Old Feb 6, 2007 | 08:18 AM
WTF? who ever told you that was lieing, don't ever listen to them again, EVER! </TD></TR></TABLE>
lol, figures. most people on here dont know wtf they are talking about anyways. but i only paid like 45 bucks for my SIRII strutbar.
Old Feb 6, 2007 | 08:35 AM
kaiba's Avatar
SiRII strut bar is the same gsr and 99-00 Si.
The type r bar fits. Loosing the 4 bolts first and adjust it in.
Old Feb 6, 2007 | 08:40 AM
Eran's Avatar
HT White Ops
lol, figures. most people on here dont know wtf they are talking about anyways. but i only paid like 45 bucks for my SIRII strutbar. </TD></TR></TABLE>
I paid $10 for my GSR bar. Mine isn't jay-dee-em though.
Old Feb 6, 2007 | 08:42 AM
Eran's Avatar
HT White Ops
All the Same Bar:
EG SiR II
EK VTi / SiR III / ViRS
EM1 Si/SiR
DC/DB GS-R
And of course ...
EK CTR (wrinkle-coated red instead of gloss black)
Old Feb 6, 2007 | 08:45 AM
philosofy1's Avatar
lol, figures. most people on here dont know wtf they are talking about anyways. </TD></TR></TABLE>
sure.
oh and yeah, you got ripped off. gotta love that jdm SIR2 tower bar.
Old Feb 6, 2007 | 08:51 AM
kaiba's Avatar
I should buy gsr/99 si strut tower bar and paint red. Sell it as JDM EK9 type r and get mad profit.
Old Feb 6, 2007 | 08:52 AM
Eran's Avatar
HT White Ops
Default Re: (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">I should buy gsr/99 si strut tower bar and paint red. Sell it as JDM EK9 type r and get mad profit. </TD></TR></TABLE>
Phase 1: Paint Bar
Phase 2: ?
Phase 3: Profit
Old Feb 6, 2007 | 08:53 AM
philosofy1's Avatar
Default Re: (kaiba)
