gsr swap into ek civic, tripple checking.
need to know what i need off a 99-00 si. already got innovative motor mount kit, 99-00 si harness and gsr harness.
Rear Tranny mount from the 99-00 Si: 50827-S04-N10
Driver side mount bracket from the 99-00 Si: 11910-P30-000
are those the only ones i need? anything else i need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay20adc2 »</TD></TR><TR><TD CLASS="quote">the harness.</TD></TR></TABLE>
opps forgot to add that, got it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug »</TD></TR><TR><TD CLASS="quote">Lower driver side tranny bracket</TD></TR></TABLE>
driver side tranny bracket? do you mean the for the front motor mount? i thought if you had innovative/hasport mounts you dont have to run it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug »</TD></TR><TR><TD CLASS="quote">AC Bracket Also</TD></TR></TABLE>
dont have ac
dont have ac
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logiT »</TD></TR><TR><TD CLASS="quote">
dont have ac
torque mounts is what they are called...run them they help
dont have ac
</TD></TR></TABLE>torque mounts is what they are called...run them they help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">
ohh ok. yeah i wasnt planning on not to. hopefully my ek bushings will fit the gsr brackets.
</TD></TR></TABLE>ohh ok. yeah i wasnt planning on not to. hopefully my ek bushings will fit the gsr brackets.
ohh ok. yeah i wasnt planning on not to. hopefully my ek bushings will fit the gsr brackets.</TD></TR></TABLE>
the stock ones do fit the gsr brackets...gl
and "tripple check"...haha
and "tripple check"...haha</TD></TR></TABLE>
haha hope so.
haha hope so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach_06 »</TD></TR><TR><TD CLASS="quote">dnt forget the rear bracket</TD></TR></TABLE>
Thank you for mentioning that .... because nobody else did
I just did my swap this is what i had to get...
Rear Bracket from a 99-00 SI
Timing belt bracket for a 99-00 SI
B- Series Tourque Mount for Tranny (mine didnt have one on)
Upper and Lower Radiator Hoses
GSR thorttle cable (mine was way to long)
I used my stock HX harness (just needed to extend a few wires)
Im not running A/C or P/S so not sure what you will need for that.
thanks guys, just ordered these
already have innovative mount kit, si harness.
also posted on here http://www.dallasimports.net/f...71556 and not sure what user WIZ is saying (read whole post). am i set with what i have already?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_dreamer »</TD></TR><TR><TD CLASS="quote">dont forget linkages</TD></TR></TABLE>
i thought all bseries linkage were the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">99-00 si throttle cable</TD></TR></TABLE>
probably should've added this, but i picked up a blox IM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">all b series are the same exept delsol vtec. get one from an si or integra and you will be good. good luck man...pm me if you need help</TD></TR></TABLE>
thats what i thought. yeah the swap is complete
