tons of misc b series parts
<u><FONT SIZE="24"><FONT COLOR="red">UPDATED</FONT></FONT></u>
<FONT COLOR="blue">JDM B16A short block odb0(dissasembled-cleaned-reassembled)_$125</FONT>
<FONT COLOR="green">JDM B16A short block obd1 (complete ready for a head)________$125</FONT>
b18a1 head with all valvetrain______________________________$35
2000 gsr intake manifold just missing tb and idle control valve____$30
jdm b18c crank (need to be polished has 1 spun rod bearing)_____$50
b series oil pump(used)____________________________________$15
ls water pump(used)_______________________________________$ 10
ls timing belt(used)________________________________________ $10
b series oil pickup_________________________________________$15
b series coolant tube with thermostat housing(used)_____________$20
b series water pump(used) _________________________________$10
b series idler pulley(used)___________________________________$5
b16 tranny brace_________________________________________$5
obd2 crank angle sensor___________________________________$15
obd 2 timingbelt crank pulley(chipped)________________________$5
obd 1 timingbelt crank pulley_______________________________$15
vx (13/16) brake master cylinder____________________________$5
ls head bolts_____________________________________________ $15
gsr head bolts___________________________________________$1 5
obd1 gsr injectors________________________________________$ 15
obd 1 gsr distributer_______________________________________ $75
gsr crank pulley___________________________________________$ 25
gsr flywheel__________________________________________ ____$10
4 gsr pistons on rods______________________________________$35
4 b16 rods(rods scratched but usable)________________________$10
3 usdm gsr pistons with wrist pins____________________________$10
2 jdm gsr pistons with wrist pins______________________________$5
blue eg steering wheel______________________________________$10
drive side eg manual mirror___________________________________$5
srs computer__________________________________________ _____$15
turn signal and wiper switches_________________________________$15
complete engine bay fuse box_________________________________$20
empty ecu case_____________________________________________$ 10
ls crank case breather box____________________________________$10
gsr crank case breather box___________________________________$10
egr vacume control box______________________________________$15
gsr engine header bracket____________________________________$5
black charcole box___________________________________________$5
b series msd modified dist cap with coil wire______________________$20
gsr fuel pump______________________________________________ _$10
5 bolt turbo exaust flange_____________________________________$10
gsr throttle cable with bracket_________________________________$5
2.5"-3" turbo coupler________________________________________$5
2.5" t-clamp_____________________________________________ __$5
3" t-clamp_____________________________________________ ____$5
92-95 oem headlights with turn signals, one pracket broken________$10
obd1 coolant temp sensor(block)______________________________$5
ls intake manifold bracket_____________________________________$5
b series coolant thermostat housing and tube____________________$15
4 oem b series wrist pin______________________________________$5
new pics comming soon
<FONT SIZE="18"><FONT COLOR="red">everything is OBO</FONT> </FONT>
i am paypal certified
hit me up at smmccurdy@hotmail.com
Modified by SoSlo at 5:24 PM 2/15/2007
b16aef4dr
10
Apr 9, 2006 12:02 PM
