Is it safe to use a clay bar to remove overspray from plastic trim?
Old Feb 5, 2007 | 05:24 PM
Baggy Spandex's Avatar
Default Is it safe to use a clay bar to remove overspray from plastic trim?
^^ What is the best way to remove overspray from plastics? I just got my OEM CTR wing today, and theres a litttttlllle tiny bit or primer overspray on the black base. Whats the best way to remove it? Will the clay bar haze the plastic?
Old Feb 5, 2007 | 05:36 PM
old-sk0ol's Avatar
Default Re: Is it safe to use a clay bar to remove overspray from plastic trim? (NAisBEST)
its just unpainted plastic?
Old Feb 5, 2007 | 05:54 PM
old-sk0ol's Avatar
Default Re: Is it safe to use a clay bar to remove overspray from plastic trim? (old-sk0ol)
if it's unpainted try claybar make sure sure the plastic and clay are both soaked with water and clean...
if that doesnt work i accidentally found that brakleen takes paint off plastic as long as you dont use too much (it could possibly warp)...used it when my taillights got spraypainted by some idiots
i paint at a bodyshop, so im not just some expletive guessing
Old Feb 5, 2007 | 06:25 PM
Type X's Avatar
peanut butter.
Old Feb 5, 2007 | 09:03 PM
Default Re: Is it safe to use a clay bar to remove overspray from plastic trim? (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">peanut butter. </TD></TR></TABLE>
yeah? no ****...
It is unpainted plastic. Kind of like a door molding
Old Feb 5, 2007 | 09:05 PM
DFW's Avatar
DFW
paint thinner? or paint over it with flat black/trim paint
Old Feb 5, 2007 | 09:06 PM
Default Re: Is it safe to use a clay bar to remove overspray from plastic trim? (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">paint thinner? or paint over it with flat black/trim paint</TD></TR></TABLE>
Trying to avoid painting it. Want to keep the 'textured' OEM plastic finish. i
Old Feb 5, 2007 | 09:10 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST &raquo;</TD></TR><TR><TD CLASS="quote">
Trying to avoid painting it. Want to keep the 'textured' OEM plastic finish. its verrrryyy light over spray. </TD></TR></TABLE>
try clay bar then. if it doesn't work for what ever reason then just clay bar your car
i used clay bar to take off paint rubbed off a garage when my friend ran into one lol
Old Feb 5, 2007 | 09:14 PM
try cly bar then. if it doesn't work for what ever reason then just clay bar your car </TD></TR></TABLE>
haha. I plan on it Ill give it a whirl.
Pics for reference...
Old Feb 5, 2007 | 09:17 PM
DFW's Avatar
DFW
try it, couldn't hurt
check here too, autobody101.com pro's
Old Feb 5, 2007 | 09:19 PM
Ill try the clay bar after work tomorrow Im just worried about it hazing the plastic, but its probably not going to happen. Its really no big deal, as the actual wing part covers it mostly, but im an **** bastard
Thanks for the responses
Old Feb 5, 2007 | 09:28 PM
MOE@Hyper16Valve's Avatar
use some break cleaner and a clean rag ...MOE@HYPER16VALVE...
Old Feb 5, 2007 | 09:30 PM
Default Re: Is it safe to use a clay bar to remove overspray from plastic trim? (MOE@Hyper16Valve)
Thanks Moe!
Old Feb 5, 2007 | 09:33 PM
old-sk0ol's Avatar
do NOT use thinner, it will fade the color, youll be able to see every smear where you had thinner on it
Old Feb 5, 2007 | 09:34 PM
Default Re: (old-sk0ol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old-sk0ol &raquo;</TD></TR><TR><TD CLASS="quote">do NOT use thinner, it will fade the color, youll be able to see every smear where you had thinner on it</TD></TR></TABLE> thanks for the info. Ill try the clay bar first
Old Nov 11, 2007 | 03:14 PM
nskforlife's Avatar
Default Re: (Baggy Spandex)
rubbing alcohol always did the trick for me...
just for future reference
Old Nov 11, 2007 | 03:15 PM
eggmygirl's Avatar
* B A N N E D *
From: Running Round At Night In Los Angeles Like A Crazy, Veva Mexco, Veva Mexco
Default Re: (nskforlife)
goof off is the ****!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
JamesV
Nov 25, 2005 04:55 PM
kniob
Jul 13, 2005 11:22 AM
AL ASPIRATED
May 11, 2004 05:50 AM
Flux
12
May 6, 2002 07:50 AM
Vu
Feb 18, 2002 12:26 AM
