SOHC ZC with and acura transmission. Will it work?
Old Feb 5, 2007 | 12:54 PM
mat18's Avatar
Default SOHC ZC and integra transmission. Will it work?
I have a SOHC ZC that I got from my buddy and he says the transmission is from a Acura 90-94. Is this possible. I tried looking for a tranny code and the only number I came up with is the serial number L3-1294846. I search on HT for the locations of the tranny codes found some good topics but no luck on my part.
Modified by mat18 at 2:29 PM 2/5/2007
Old Feb 5, 2007 | 12:55 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: SOHC ZC with and acura transmission. Will it work? (mat18)
From what Acura?
if the tranny is an l3 yes it'll fit on a D. He might be mixed up.
Old Feb 5, 2007 | 01:12 PM
kyle h.'s Avatar
Default Re: SOHC ZC with and acura transmission. Will it work? (Max The Amazing)
Some integras in japan came with the sohc zc, but they don't call them acuras over there...
mat18's Avatar
He says it form a integra 90-94. Is this right?
Old Feb 5, 2007 | 01:18 PM
mat18's Avatar
when I got my axle my friend says get the axle from a 90-94 integra non abs. They fit but the wheel is locking up. when I loosen the axle bolt it wont lock up any more but when I tighten the axle bolt the wheel locks up. What are the correct axle I should get?
Old Feb 5, 2007 | 03:32 PM
dr_latino999's Avatar
Default Re: (mat18)
Did you remove the dust ring?
Old Feb 5, 2007 | 05:44 PM
IP RACING's Avatar
Default Re: (dr_latino999)
yea bro remove the dust ring I had the same problem once I removed the ring it was golden turned perfect
Old Feb 5, 2007 | 08:55 PM
mat18's Avatar
cool I'm going to try it in the morning
Old Feb 6, 2007 | 05:46 PM
mat18's Avatar
removing the dust ring worked like a charm.
sean burke
Jun 25, 2014 11:09 AM
civicstyles~
11
Apr 24, 2007 04:56 PM
EG8R
Aug 3, 2006 07:09 PM
*Boostwerks*
Sep 14, 2003 11:03 AM
rasta420
Feb 14, 2003 07:20 AM
