Problems with my H22a'd CB7, Need Help!
gotta 95' jdm h22a swap..i dont have a oil pressure switch and theres a Map sensor on top of my throttle body isn't that for OBD2? but all the wiring is obd1..car isn't starting i wanted to know if this is the problem
OBDI also has the MAP sensor on top of the throttle body. Do you have the ECU wired correctly? And what year did the H22A come out of? Using the same year engine as your car makes it much easier.
i have a 90' accord..its a jdm 95 h22a that came with the obd1 p13..everythings plugged in except the IAB i just dont have a oil pressure switch, and i didn't hear about wiring up the MAP sensor on top of the jdm h22a i didn't think it was needed
Do you have an inductive timing light, you could just check it. If the timing were off, you'd probably hear the pistons smashing into the valves. If it starts with quikstart or whatever, then I'd look at your fuel pump/filer, maybe your injectors. I swapped an engine that had been sitting a while before and the injector rail was junk, just used the injectors off the old engine and it worked fine.
cb7tuner.com is your freind. You dont have to do any thing to the map on top of the TB. Your map is on the firewall and its still plugged in. dont worry about that.
wut up man my bro has an accord with a H22a and thats all he messes with. He said his pretty much did the same thing because the engine sat for a lil bit. he said just take a ratchet or something and tap on all of the injectors. If they are clogged it might knock it loose or you could just take the whole fuel rail off and clean everything out. He is also a member of cb7tuner.com and if you go there you will find out alot of info.
vtech_is_4_phones
Jan 22, 2007 08:35 AM
trooper0641
Feb 15, 2006 11:01 AM
accordracer1995
Jul 3, 2004 06:21 PM
