Windshield Water Fluid Pump?
Old Feb 5, 2007 | 12:19 PM
J-who's Avatar
Default Windshield Water Fluid Pump?
I had my car parked for 1/2 the year, just got it back on the road... and now for some reason my front windshield fluid pump does not work.
The rear one works fine though.... so I figure they must be 2 different pumps? When the car is off, you can hear the rear pump do its thing.. but the front one does nothing.
Anyways.. I've search online and in the Haynes book with no luck. Where is she located? Once I find it, I can replace it
ps. Its a 1990 GS integra
Thanks
J-who
Old Feb 5, 2007 | 12:23 PM
davidluko's Avatar
It's in the tank, at least on 94+ but I don't see why it'd be out of the tank on the older ones. Mine in my 98 Integra doesn't work either (it runs out a bit of water but doesn't have enough force to squirt), after not using it for about a year. See if your windshield fluid reservoir has a plug/wires running to it.
Old Feb 5, 2007 | 12:24 PM
J-who's Avatar
Default Re: (Hatch_R)
Oh wow, looks like Ill just have to replace the whole thing I guess?
Yeah the things filled right to the top, and not even a drop comes out ... and no noise from the motor..... bah.
Old Feb 5, 2007 | 01:18 PM
davidluko's Avatar
Well I don't know if that's how it is on the older Integras but that's what I'd guess. My motor makes a noise, it's pretty loud (not sure if that's normal for it to be that loud), and it just barely leaks water out of the squirters. I don't know, maybe mine is blocked up from something. You should be able to find one pretty cheap on H-T classifieds or maybe a local junkyard, especially with the wire-tuck fad that everyone's been doing.
moonchies
Aug 11, 2017 03:03 PM
TheOnlyBobaFett
Aug 26, 2013 09:42 PM
wdissident
Feb 9, 2009 10:53 PM
I Like Boost
Aug 28, 2003 06:42 PM
zijiejijeijrkjk
Mar 15, 2002 05:28 AM
