Car not starting help please!
Old Feb 5, 2007 | 11:54 AM
bacnoonoi's Avatar
Default Car not starting help please!
I just replaced my starter and my car started for a couple hours then when i tried to start it again it wouldnt start up. I tapped on the starter and it tried to start but didnt. I also broke one of the nuts that is on the valve cover. The nut where the ground wire or w/e is attatched to. I dont know if this affects it. Please help thank you.
Old Feb 5, 2007 | 11:57 AM
HBK's Avatar
HBK
Default Re: Car not starting help please! (bacnoonoi)
Well if your ground isnt hooked up where that nut broke then thats your problem.
Make sure that ground is properly hooked up son!
Old Feb 5, 2007 | 12:05 PM
bacnoonoi's Avatar
Default Re: Car not starting help please! (HBK)
how can i fix it? the nut broke offf??
Old Feb 5, 2007 | 12:13 PM
90sedan's Avatar
Try and reattach the ground to another location on the valve cover. It won't start till you do that.
Old Feb 5, 2007 | 12:14 PM
89efDUSTY's Avatar
The valve cover ground is not mandatory...check your main relay. I just ran my car without the vc ground for like three weeks and put it on yesterday...
Old Feb 5, 2007 | 02:25 PM
XxJDMugenCivicxX's Avatar
Default Re: Car not starting help please! (89efDUSTY)
its just couse it is a god dam honda tempered motha ****** huh lol try the relay and if that aint it see if it has comp and spark
Old Feb 5, 2007 | 03:25 PM
SLPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bacnoonoi &raquo;</TD></TR><TR><TD CLASS="quote">how can i fix it? the nut broke offf??</TD></TR></TABLE>
if the bolt broke off into the thread hole... try usin/purchasin a tap n die kit. mine broke off once in my EK, but the tap n die kit didnt work cuz of the way the bolt broke off so deep. so i had to drill it out with a drill bit almost the size of the bolt but not a lil smaller...then i had to use a heily coil(sp?).
but HBK's correct:<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote">Well if your ground isnt hooked up where that nut broke then thats your problem.
Make sure that ground is properly hooked up son!</TD></TR></TABLE>
burks
Aug 3, 2007 01:40 PM
bacnoonoi
Feb 5, 2007 10:19 AM
egriffith45
Aug 19, 2006 08:56 PM
Contender25
20
Jan 19, 2006 09:18 PM
hybrider
Mar 24, 2002 10:32 PM
