B18c Dart block/ huge motor for sale "all is brand new"!!!
Old Feb 5, 2007 | 11:10 AM
righthandsti's Avatar
Default B18c Dart block/ huge motor for sale "all is brand new"!!!
This is all yours for $6500 plus shipping!! I need it all gone fast!! I have over $10,000 in all of this stuff easy!! Yes, it does suck but I'm just done with this stuff! Everything is brand new in the box!! Will drive to meet within a couple 100 miles or so if needed! I just really never got started on the project very well! Any questions and/or buyers you can e-mail me at righthandsti@yahoo.com If you want pictures or anything just let me know! Thanks everyone Todd
Here's the new list with everything that comes with this deal.
DART BLOCK B18 #31496701 212mm x 81.5mm Retail: $2325.00 Sell: $1900.00
EAGLE CRANKSHAFT #1835041772 4340 B18A/B, B20B/Z Retail: $659.95 Sell: $620.00
EAGLE "ESP" H-BEAM CONNECTING RODS #CRS5394A3D Retails: $359.95 Sell: $340.00
WISECO PISTONS AND RINGS TURBO COATED (RINGS ARE INSTALLED, WRIST PINS ARE FITTED) #K545M84 1.1815 x 84.0MM BORE 3.3071
(8 TO 1 COMPRESSION) Retail: $600.00 Sell: $500.00
CLEVITE BEARING KIT COMPLETE WITH TURBO COATING Sell: $100.00
B16 JDM HEAD PORTED AND POLISHED, VALVE JOB, AND HUGE VALVES (EVERYTHING YOU CAN DO IS DONE TO IT) Sell: $1850 with
PBM SPORTMAN OVERSIZED VALVES #2202, SPRINGS #3000, AND RETAINERS (PBM complete assembly lube 2oz.)
CROWER TITANIUM VALVE LOCKS 5.5 MM #86115T-16 Retail: $171.05 Sell: $155.00
CROWER TURBO CAMSHAFTS (INTAKE) & (EXHAUST) SPECIALY ORDERED #63401T-2
Duration Lift Clearance
intake 308 degrees .467 .006
exhaust 309 degrees .445 .008 Sell: $575.00
PHATOM GRIP SUPER LITE ALUMINUM RACE ROCKERS (RED) #PGSLRR Retails:$541.67 Sell:$441.00
MOROSO ALUMINUM OIL PAN, GASKETS, AND PICK-UP TUBE Sell: $375.00 with pick-up tube and gaskets
TWO CROWER ADJUSTABLE CAMSHAFT GEARS (SILVER & BLACK) #86054BC Retail: $160.00 each Sell: $155.00
RC engineering 1000cc injectors $340.00
AEM FUEL RAIL B16A2 (BLUE) #25-103B Retail: $144.00 Sell: $140.00
AEM ADJUSTABLE FUEL PRESSURE REGULATOR (BLUE) #25-300B Retails: $182.71 Sell: $142.00
PROFESSIONAL PRODUCTS POWER+PLUS TYPHOON INAKE MANIFOLD (POLISHED CHROME) PORTED AND POILSHED. PORT MATCHED TO THROTTLE BODY AND PORT MATCHED TO HEAD AND GASKETS #59000 Sell: $250.00
CUSTOM COMETIC HEAD GASKET Sell: $100.00
B16A TODA TIMING BELT (RED) #06141-B16-00 ell: $190.00
HONDA OEM INJECTOR RESISTER BOX #30700-SH3-013
Sell: $85.00
ALL NEW TIMING PULLEYS AND TENSIONERS FROM TOPLINE
Sell: $100.00
NEW TOPLINE CRANKSHAFT SEAL Sell: $30.00
NEW ITM OIL PUMP Sell: $110.00
HONDA OEM PRELUDE MOTION ASSY. SPRINGS #14820-PCB-003
Sell: $75.00
WATERPUMP Sell: $ 50.00
FIDANZA ALUMINUM FLYWHEEL AND NEW CLUTCH (OEM) #NW-9255 Sell: $200.00
CUSTOM ENGINE WIRING HARNESS Sell: $300.00
JDM TRANSMISSION WITH LSD (HYDRO) 30k on it Sell: $900.00
EVERYTHIING ELSE IS ALL JDM FROM A SWAP I HAD FROM
HMOTORSONLINE!!!!! mounts and everything else under hood
ARP MAIN STUDS AND ARP HEAD STUDS Sell: $186.00 Both
All stock parts from the head!Cams, Gear, Valves, Springs, ect.
This comes with better much everything that you need for the whole motor swap, I will throw in all of the motor motors for a 92-95 civic swap and axles!!
Old Feb 6, 2007 | 05:48 AM
Default Re: B18c Dart block/ huge motor for sale "all is brand new"!!! (righthandsti)
I know somone wants to buy all of this stuff!! HAHA I also replied to all of the e-mails guys! Thanks Everyone Todd I really need this stuff gone!! I also have receipts for almost everything!!
JDMegKing
Sep 1, 2009 06:32 PM
eikki
Mar 18, 2007 01:39 PM
righthandsti
Feb 5, 2007 10:50 AM
freakie
Jul 5, 2003 07:13 AM
