will a obd0 distributor fit on a sohc vtec head?
like the title says im just wondering if i can use an obd0 distributor on a obd1 vtec head, sohc of course. will it bolt up and if it wont work, than why not? i just want to know if i can use an obd0 to obd1 conversion harness and use an obd0 distributor. thanks for the help.
it wont bolt up, the obd1 sohc vtec head is a blacksheep from everything else,,but you can make the other distributors fit by cutting off the legs then put it on,, and using some washers and bolts to hold it on...rigged yes,but works fine.
take the obd-0 distributor and put it on the head and you'll see what i mean..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap »</TD></TR><TR><TD CLASS="quote">All I had to do was drill a little bit out of the obd-o dizzy and it worked fine on my z6 head</TD></TR></TABLE>
you're smart,,i like to cut ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">
you're smart,,i like to cut ****.</TD></TR></TABLE>
LOL!!!
That has to be one of the best posts i've read all day.
LOL!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22turbofiend »</TD></TR><TR><TD CLASS="quote"> i just want to know if i can use an obd0 to obd1 conversion harness and use an obd0 distributor</TD></TR></TABLE>
you can't use OBD0 distributor with OBD1 ECU, if that is your plan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">you can't use OBD0 distributor with OBD1 ECU, if that is your plan</TD></TR></TABLE>
true dat
true dat
this is what i did..( 95 d15b ) OBDO DIZZY ..INTAKE..ECU...WONT LOOK NICE BUT SURE BEATS DRILLING AND CUTTING...
NOW GOING B16 SOME ONE HELP ME..!... https://honda-tech.com/zerothread/1887217
Jimster480
Oct 30, 2009 01:36 PM
ek_civic96
May 6, 2008 12:58 AM
