si swap poblems ek 96 cx
Old Feb 5, 2007 | 09:51 AM
95accord10.3's Avatar
Default si swap poblems ek 96 cx
i have a problem i caint find the other connection that goes on the ecu the one that should split from the green connector on my car so right now only 2 connectors are on the ecu i dont know what to do can somone please help let me know
its an obd2 99 si my hb is a cx 96
Old Feb 5, 2007 | 10:53 AM
Sloshy's Avatar
it sounds like you're using 99-00 si harness
you need to use a 96-98 ex harness, or your original harness wired for vtec....
Old Feb 5, 2007 | 01:14 PM
Default Re: si swap poblems ek 96 cx (95accord10.3)
i have the cx harness from my d16 but i dont think it would fit the si motor or the si ecu you think i can buy a wire harness
Old Feb 7, 2007 | 06:59 PM
Sloshy's Avatar
ok thats perfect the harness does fit the motor but you'll have to mod it a little don cut any wires just slice in to the loom and pull the plugs to were they supposed to be....
and for the ecu what i did on my was just get a jumper harness to obd1 and ran an obd1 ecu.. you can also get a jumper harness from obd2a(96-98) to obd2b(99-00) this one will let youy run the Si ecu and (or) pass emission if you do it right
goofyej6
Dec 15, 2007 05:04 AM
95accord10.3
Feb 6, 2007 03:21 PM
TheYellowDart
Aug 18, 2005 12:10 AM
tonyxcom
Aug 15, 2002 04:59 AM
