no heat (cool air) on idle
Old Feb 5, 2007 | 09:47 AM
fraknstien's Avatar
Default no heat (cool air) on idle
its for my '97 civic, whenever my car is idle, cool air starts to blow out of my vents,
And when im driving, my heat isn't all that warm...
last winter from what i remember my heat was working perfectly fine, so maybe something got old and stopped working? but i dunno what...
before i take it to a shop , i wanted to know what could be some of the problems.
Old Feb 5, 2007 | 09:48 AM
YoungKadafi's Avatar
maybe your lever broke which opens the heater core? mine snapped and i didnt even know it
Old Feb 5, 2007 | 10:05 AM
Cboi's Avatar
i have the same problem when i switch it to hot or cold its just cool air same as when im try'n to defrost.. i thot it was my heater core.... so the lever is behind the console?
Old Feb 5, 2007 | 10:27 AM
bottom of the blower, and there is another one on the firewall of the car, by the battery
Old Feb 5, 2007 | 10:29 AM
for my car to kick into warm air, i have to give it a quick rev up to 4k, which somehow moves the lever into the warm position.
If you mess with the lever, you will notice its almost like its hydro controlled. doesnt seem like a cable. Anyway if I give my car a quick jerk, it usually pumps the hot air out....otherwise i could be sitting in 100* weather, on the warm setting, blowing cold air
Old Feb 5, 2007 | 02:46 PM
fraknstien's Avatar
Default Re: (YoungKadafi)
i will check that lever
anyone else got any input on this?
Old Feb 5, 2007 | 02:50 PM
MonkeyBoy668's Avatar
Default Re: (fraknstien)
What's your temp gauge doing? Does it warm up to middle range, then slowly start dropping when you drive on the highway?
That's what happened to me when my thermostat went a winter or two ago - evidently it was stuck open.
Old Feb 5, 2007 | 03:42 PM
ek_kid's Avatar
Default Re: (MonkeyBoy668)
yeah most of the time it the thermostat.
Old Feb 5, 2007 | 04:16 PM
cisurfer1's Avatar
I had the same problem a month ago...T stat
Old Feb 5, 2007 | 05:19 PM
fraknstien's Avatar
Default Re: (cisurfer1)
i thought it was the thermostat too but my temp gauge is always in the same spot after warming up .. could it still be the thermostat?
1fastvtec
Jan 26, 2015 05:12 PM
dankstereg6
Jan 2, 2010 10:02 AM
scrolanky
Nov 5, 2008 07:21 PM
Ritter57
May 25, 2008 10:01 AM
